On Going BB issue
tolmie35
On Going BB issue
Hi guys, this is a general email as I know im not the only one, this is the 2nd week I've been having issues with broadband. Xbox live is affected, amazon prime is affected, twitter is affected and also sky, can you please advise how long this is going to go on for. Before you ask I've rebooted my router many times over the last 2 weeks, IT is my job so technical wise I know what I'm doing. Do we have a time frame for when theses issues are going to be resolved, I will be connected to the internet and certain service such as above will come and go. Im based in Glasgow.
Fixes: 62
Re: On Going BB issue
tolmie35
Im on Fibre, im using wifi and cable. Using my own TP link router and have been for months.
Fixes: 62
So you posted in the wrong section - Moderator notified
This is what we need https://community.plus.net/t5/Fibre-Broadband/Fibre-Speed-Faults/m-p/1270253#U1270253
tolmie35
My connection issues to an extend have been resolved but im not getting the speed as described in the email I received, I l live 2 mins from the exchange and no from the BT engineer that I can get the full 80mb if subscribed to it, why am i only getting 40mb an not 52mb
Fixes: 187
Can you log into your router and disconnect then reconnect?
 Matthew Wheeler
tolmie35
Hi Matthew, I'll do it once I get home, have you made some changes.
Fixes: 187
Yes which should hopefully do the trick.
 Matthew Wheeler
tolmie35
Still not resolved.
tolmie35
Guys any updates on this, I did what you requested and sent an update, heard nothing back.
tolmie35
Guys this support isn't good enough, please look into why I'm getting no more than 30mb and should be getting 50mb.
Fixes: 180
Apologies that this thread was missed from the 19th. Glad to see we got some improvement over on the other thread.
 Harry Beesley
