Off-Peak Traffic Shaping on P2P - WHY?
GazProm
I am on the 38MB Fibre service I am noticing that my torrent downloads are capped at around 2.50MB/s but I notice I'm able to download large files via a browser sometimes at ~4.50MB/s and that is at any time of day.
I understand you do have traffic shaping measures and I am not arguing about that but I never get anything above this even in off peak times (i..e now).
Why are Torrent bandwidth caps not lifted/increased in off peak times?
I am not really using other web services so my full bandwidth should be available and I do not need any bandwidth management services. If I need some I am highly computer literate and can just install a program to do this so don't need Plusnet to do this for me. I feel like I am not getting the full service that I am paying for.
Can someone please tell me why this is implemented like this or whether there is something wrong at the PlusNet end which has not been switched on?
gofaster
Re: Off-Peak Traffic Shaping on P2P - WHY?
It *isn't* implemented like that.
Please be careful with your units - your service is up to 38Mb/s (Mega bits per second) which will give around 4.5 MB/s (mega bytes per second) maximum.
Does your P2P client display peers and a speed graph? If the speed graph has a flat line at 2.5 MB/s then this might indicate capping by PlusNet but if it fluctuates then it is probably just a matter of being limited by the upload speed of your peers.
Can you try a high seeded file like this http://www.ubuntu.com/download/alternative-downloads and report the speed you get back?
GeordieMark
4.5MB/s sounds about right for a 38Mbps connection (taking into account overheads, ip profile lower than sync etc)
Xup
Gaz... gateway hop that will sort it for you....does the same to my connection, I just gateway hop and back to 4.7MB/s
