Odd TBB test ?
- Odd TBB test ?
Re: Odd TBB test ?
25-05-2017 11:03 AM
Can you paste us a traceroute?
Ex-Broadband Service Manager
Re: Odd TBB test ?
25-05-2017 11:07 AM
@rongtw wrote:
gateway pcn-ir01. is terrible pages slow load buffering on iPlayer ETC gaming is dire , and every time i drop connection
That sounds like you were rebooting your router (or similar) a bit but it doesn't look like it from your RADIUS Log:
Can you describe what you were doing for me?
Re: Odd TBB test ?
25-05-2017 12:58 PM
@Kelly yes from my Router Asus AC68U , i just reboot the connection , or drops the session for 60 seconds normally it would connect to a new gateway
Ps the big gaps are when i powered off the router
Re: Odd TBB test ?
30-05-2017 8:21 PM - edited 30-05-2017 8:22 PM
@Kelly Just been trying playing BF4 awfull gateway psb-bng01. BT test says i only lost 10 download and 5 up BUT
Re: Odd TBB test ?
02-06-2017 4:36 PM
We are at a bit of a loss on this now. I don't doubt you've got an issuue based you you seeing iplayer/gaming failing which coincides with speed test drops by we can't see anything on our side which would cause this. You were reporting similar issues to @30FTTC06 and @philcecchini, both of this resolved themselves without our input which leads us to suspect something on the wholesale side we aren't seeing in their cases. As to why that could apply to you and not clear up in the same way is a different question.
Last few things to check really would be if you've got another router to see if you see the same problems on it, and to also check you've not got anything which cause be possibly causing interference which your line is picking up.
Re: Odd TBB test ?
02-06-2017 6:52 PM - edited 02-06-2017 6:52 PM
@Kelly Mr Safron suggest that if nowt shows on your test , as a last resort it may be My PC so tomorrow i intend to Erase SSD and fresh install everything including drivers , it is possible the LAN chip on MB Intell 1518V has updated a driver thats corrupted .
So if i refresh all from original MB disc and dont update see what happens .
Ps i had tried a alternative router previously
Re: Odd TBB test ?
02-06-2017 7:41 PM
How long ago was that? I'm guessing that it was long enough ago that lots of things will have changed since then and it probably should be re-tested.
Re: Odd TBB test ?
02-06-2017 8:08 PM - edited 02-06-2017 8:09 PM
@ejs when this started i tried it
i was always told to locate a problem its a process of elimination
Just for clarity i will retest tomorrow
Re: Odd TBB test ?
03-06-2017 6:10 AM - edited 03-06-2017 8:37 AM
first test with 270n and BT box
Re: Odd TBB test ?
03-06-2017 6:27 AM - edited 03-06-2017 6:41 AM
well i dont think the router is the problem gateway pcn-bng01.
Re: Odd TBB test ?
03-06-2017 8:03 AM - edited 03-06-2017 8:04 AM
and a normal ish test
Re: Odd TBB test ?
03-06-2017 6:11 PM - edited 03-06-2017 6:12 PM
back to asus router now , and a fresh install OS . gateway psb-bng03.
No MS driver updates just from disc and then latest Intell driver for Intel® I218V, 1 x Gigabit LAN Controller
Re: Odd TBB test ?
06-06-2017 2:11 PM
It was worth a test to see it happening on both devices. The ASUS does look a little different though. Do you see that slow ramp up on the other router?
Re: Odd TBB test ?
06-06-2017 3:24 PM
@Kelly yes but didnt want to fill up here with tests
Re: Odd TBB test ?
12-06-2017 7:17 AM
