Odd TBB test ?
- Odd TBB test ?
Re: Odd TBB test ?
09-03-2017 11:10 AM
Ouch. Yeah, that doesn't look anything like what we've been looking like. Out of interest, what does their other speedtester show (and is that the old one?)
Ex-Broadband Service Manager
Re: Odd TBB test ?
09-03-2017 11:17 AM - edited 09-03-2017 11:18 AM
As of 11:15 this morning, it's
But this tester normally gives reasonable results, as you can see from my other contributions to this thread
(edit, last nights test was their newer one)
Re: Odd TBB test ?
10-03-2017 4:44 PM
gateway pcn-bng04. , my connection is like a roller coaster
http://www.thinkbroadband.com/speedtest/results.html?id=148916399624130286670
Re: Odd TBB test ?
10-03-2017 5:53 PM
I'm having the issue forward and reverse today.
iperf3 -c ping.online.net -p 5200 -b 30M -R
Connecting to host ping.online.net, port 5200
Reverse mode, remote host ping.online.net is sending
[ 4] local Router port 17317 connected to 62.210.18.40 port 5200
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 518 KBytes 4.24 Mbits/sec
[ 4] 1.00-2.00 sec 1.94 MBytes 16.3 Mbits/sec
[ 4] 2.00-3.00 sec 2.78 MBytes 23.3 Mbits/sec
[ 4] 3.00-4.00 sec 3.62 MBytes 30.4 Mbits/sec
[ 4] 4.00-5.00 sec 3.82 MBytes 32.0 Mbits/sec
[ 4] 5.00-6.00 sec 3.78 MBytes 31.7 Mbits/sec
[ 4] 6.00-7.00 sec 3.37 MBytes 28.3 Mbits/sec
[ 4] 7.00-8.00 sec 3.52 MBytes 29.5 Mbits/sec
[ 4] 8.00-9.00 sec 2.96 MBytes 24.8 Mbits/sec
[ 4] 9.00-10.00 sec 3.53 MBytes 29.6 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 30.2 MBytes 25.4 Mbits/sec 26 sender
[ 4] 0.00-10.00 sec 30.1 MBytes 25.2 Mbits/sec receiver
iperf Done.
iperf3 -c ping.online.net -p 5200 -b 1.5M
[ 4] local Router port 7273 connected to 62.210.18.40 port 5200
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.01 sec 78.8 KBytes 641 Kbits/sec 6 9.89 MBytes
[ 4] 1.01-2.00 sec 135 KBytes 1.11 Mbits/sec 1 27.7 MBytes
[ 4] 2.00-3.00 sec 176 KBytes 1.44 Mbits/sec 2 23.7 MBytes
[ 4] 3.00-4.00 sec 179 KBytes 1.46 Mbits/sec 2 19.8 MBytes
[ 4] 4.00-5.00 sec 176 KBytes 1.44 Mbits/sec 2 15.8 MBytes
[ 4] 5.00-6.00 sec 177 KBytes 1.45 Mbits/sec 1 19.8 MBytes
[ 4] 6.00-7.00 sec 179 KBytes 1.46 Mbits/sec 1 29.7 MBytes
[ 4] 7.00-8.00 sec 174 KBytes 1.43 Mbits/sec 2 19.8 MBytes
[ 4] 8.00-9.00 sec 176 KBytes 1.44 Mbits/sec 1 21.8 MBytes
[ 4] 9.00-10.00 sec 183 KBytes 1.50 Mbits/sec 1 29.7 MBytes
[ 4] 0.00-10.00 sec 1.59 MBytes 1.34 Mbits/sec 19 sender
[ 4] 0.00-10.00 sec 1.55 MBytes 1.30 Mbits/sec receiver
iperf Done.
I can't be bothered to turn of traffic shaping to show a silly graph.
Re: Odd TBB test ?
10-03-2017 6:34 PM
@30FTTC06 i am sorry am at a loss , i dont understand Iperf can you explain basically what i am looking for
Re: Odd TBB test ?
10-03-2017 8:03 PM
Yeah it's a 10 second single threaded speed test showing the speed readings each second as shown on the left,
UDP or TCP as follows below, if your line is working as expected with no congestion etc you will get results as follows below. Just for the reference they were done one after the other about 15 minutes ago which is odd because all seems ok now!
iperf3 -c ping.online.net -p 5200 -u -b 30M Connecting to host ping.online.net, port 5200 [ 4] local Router port 62497 connected to 62.210.18.40 port 5200 [ ID] Interval Transfer Bandwidth Total Datagrams [ 4] 0.00-1.00 sec 3.23 MBytes 27.0 Mbits/sec 413 [ 4] 1.00-2.00 sec 3.58 MBytes 30.0 Mbits/sec 458 [ 4] 2.00-3.00 sec 3.58 MBytes 30.0 Mbits/sec 458 [ 4] 3.00-4.00 sec 3.58 MBytes 30.0 Mbits/sec 458 [ 4] 4.00-5.00 sec 3.57 MBytes 29.9 Mbits/sec 457 [ 4] 5.00-6.00 sec 3.58 MBytes 30.0 Mbits/sec 458 [ 4] 6.00-7.00 sec 3.58 MBytes 30.0 Mbits/sec 458 [ 4] 7.00-8.00 sec 3.58 MBytes 30.0 Mbits/sec 458 [ 4] 8.00-9.00 sec 3.57 MBytes 29.9 Mbits/sec 457 [ 4] 9.00-10.00 sec 3.58 MBytes 30.0 Mbits/sec 458 - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams [ 4] 0.00-10.00 sec 35.4 MBytes 29.7 Mbits/sec 35.243 ms 4351/4494 (97%) [ 4] Sent 4494 datagrams iperf Done. iperf3 -c bouygues.testdebit.info -p 5200 -b 30M -R Connecting to host bouygues.testdebit.info, port 5200 Reverse mode, remote host bouygues.testdebit.info is sending [ 4] local Router port 18216 connected to 89.84.127.53 port 5200 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 3.23 MBytes 27.1 Mbits/sec [ 4] 1.00-2.00 sec 3.62 MBytes 30.4 Mbits/sec [ 4] 2.00-3.00 sec 3.63 MBytes 30.4 Mbits/sec [ 4] 3.00-4.00 sec 3.50 MBytes 29.3 Mbits/sec [ 4] 4.00-5.00 sec 3.63 MBytes 30.4 Mbits/sec [ 4] 5.00-6.00 sec 3.50 MBytes 29.4 Mbits/sec [ 4] 6.00-7.00 sec 3.62 MBytes 30.4 Mbits/sec [ 4] 7.00-8.00 sec 3.63 MBytes 30.4 Mbits/sec [ 4] 8.00-9.00 sec 3.50 MBytes 29.3 Mbits/sec [ 4] 9.00-10.00 sec 3.63 MBytes 30.4 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 35.9 MBytes 30.1 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 35.7 MBytes 30.0 Mbits/sec receiver iperf Done.
Go figure..... anyway. if I'm getting a curve on a TBB test, you will also see that reflected in the figures on the right side of the test ie
5mbps
12mbps
22mbps
30mbps
30mbps
30mbps
30mbps
Hope that helps!
Re: Odd TBB test ?
10-03-2017 8:14 PM
Just to note! some servers do udp while others don't, also for a fast line like yours you would be better off leaving the bandwidth flag OFF as follows
iperf3 -c bouygues.testdebit.info -p 5200 -R
For Uploads do.
Re: Odd TBB test ?
13-03-2017 8:29 AM
After a good weekend on gateway pcn-bng02.
i got a slight drop this morning http://www.thinkbroadband.com/speedtest/results.html?id=148939356205500636715
Re: Odd TBB test ?
13-03-2017 2:19 PM
well Mr Brokenreach have been at my Green box outside , thought i would try a test http://www.thinkbroadband.com/speedtest/results.html?id=148941386204064860183
Re: Odd TBB test ?
13-03-2017 7:57 PM
Normal tester - http://www.thinkbroadband.com/speedtest/results.html?id=1489434602245880555
Alternative tester - http://www.thinkbroadband.com/speedtest/results.html?id=148943468745455228182
(It has been confirmed today that my connection is below the lower estimate, but the above results are way below :()
Re: Odd TBB test ?
16-03-2017 9:55 AM
Those look ok. (certainly not affected by this issue
Re: Odd TBB test ?
17-03-2017 7:35 PM
Normal tester- http://www.thinkbroadband.com/speedtest/results.html?id=1489774763708406955
Alternate tester - http://www.thinkbroadband.com/speedtest/results.html?id=148977480423446338433
BTw tester - Download Speed 17.41Mbps Upload Speed 1.82Mbps (shame BT's one doesn't have a graph)
Then repeated
Normal tester - http://www.thinkbroadband.com/speedtest/results.html?id=1489778641738332155
Alternate tester - http://www.thinkbroadband.com/speedtest/results.html?id=148977860950473956735
BTw tester - Download Speed 14.58Mbps Upload Speed 1.70Mbps
Re: Odd TBB test ?
17-03-2017 8:57 PM
My upload is faster than my synch rate - that's odd!
http://www.thinkbroadband.com/speedtest/results.html?id=1489783982403168855
Re: Odd TBB test ?
19-03-2017 2:08 PM
@Kelly dropped a fair bit today http://www.thinkbroadband.com/speedtest/results.html?id=148993212514456422535
Re: Odd TBB test ?
23-03-2017 11:52 AM
Hey @rongtw, we've come to the conclusion that whatever is going on with your line isn't to do with the issues we were seeing originally. It looks like you get chunks of errored seconds on your line which may explain the random slowdowns and performance problems. We've got someone raising a fault on your account to investigate for you.
