Odd TBB test ?
- Re: Odd TBB test ?
Re: Odd TBB test ?
16-02-2017 10:01 PM
still on pcn-bng1 http://www.thinkbroadband.com/speedtest/results.html?id=14872818650172504906
Re: Odd TBB test ?
17-02-2017 12:40 AM
NO YV 19:05 http://www.thinkbroadband.com/speedtest/results.html?id=1487271901313856055
NO YV 23:43 http://www.thinkbroadband.com/speedtest/results.html?id=1487288622358520155
Test and YV IP at exact same time 00:06 http://www.thinkbroadband.com/speedtest/results.html?id=1487288622358520155
YY On and streaming fine 00:16 http://www.thinkbroadband.com/speedtest/results.html?id=1487290578559579055
Then used the old tester, YV IP still running, which gives this:
But using the link given on the old page shows the above results in the new result way, and it actually looks good
http://www.thinkbroadband.com/speedtest/results.html?id=148729121607367931303
Re: Odd TBB test ?
17-02-2017 1:10 AM
Top results are on the newer tester
Bottom results are using the older tester - which atm are giving good results
YV TV still on an IP channel
Re: Odd TBB test ?
17-02-2017 7:39 AM
no better this morning pcn-bng01.
http://www.thinkbroadband.com/speedtest/results.html?id=148731695625067584432
Re: Odd TBB test ?
17-02-2017 10:56 AM
why cant i have this http://www.thinkbroadband.com/speedtest/results.html?id=148732811615287082469
All the time , and its same gateway
Re: Odd TBB test ?
17-02-2017 12:18 PM
@rongtw I think it's a red herring, but look at my previous post.
The top result using their 'new' tester gives erratic readings (upper left image) and the results are normal for me (upper right), as in they all all over the place.
The (lower left) older style test results page was only tested 2 mins later and the other (lower right) image is a copy of the older test (there is a link on that older page to show the results in the newer style).
What I'm getting at is - try the new tester and check the graph and compare it to the older tester. Is one bad and the other good?
Re: Odd TBB test ?
17-02-2017 1:09 PM
But the erratic single thread problem was the original topic of this thread - sometimes single threads would be fine, then they'd be rubbish (and a solid rubbish for the duration of the test) and then they'd be OK again.
Re: Odd TBB test ?
17-02-2017 1:51 PM
That's what I was getting at, I think....
Both of those tests in my post above (using the new and old testers) were carried out with in 2 mins of each other.
I've never had a decent result since joining PN using mainly the new version. The good result only came from the old tester - so the old tester is the only one to date that gives a result I'd expect to see.
I'll compare both again because I'm not convinced one is now good as the other is still bad - hence the red herring.
Re: Odd TBB test ?
17-02-2017 2:02 PM
I've just ran both testers, and as you'll see the first (newer) tester gives erratic results for 1x and 6x
The older tester gives good (for me anyway) results for 1x and 6x
New tester = very poor = http://www.thinkbroadband.com/speedtest/results.html?id=1487339657601409655
Old tester = better = http://www.thinkbroadband.com/speedtest/results.html?id=148733963625767893870
So, is it something at TTB end with the setup of the new tester, or have PN fixed one part that goes to TBB but the other still needs work, or do all of us have poor connections* with PN?
*excluding the 2 week issue that some of us have witnessed lately.
Re: Odd TBB test ?
17-02-2017 3:14 PM - edited 17-02-2017 3:14 PM
TBB have stated on their forums its not at their end ! , Other ISP have fixed this problem ? http://forums.thinkbroadband.com/plusnet/4519937-single-thread-speed-issues.html?vc=1
PN did say that BT had identified a potential problem and changes have been made. as stated by @scrookes
Re: Odd TBB test ?
17-02-2017 3:44 PM
I meant recently (within the last few days) as both testers were erratic for me in previous (days) tests
I have to agree that there must be some gremlins in the new network - BTwSpeedtest results have also been hit n miss. I know this has been like this for years, but I'm thinking that are these new reports are down to the new network too. Other things that have been creeping on these forums is this odd 14 day cycle, where every device starts going slow but is restored by powercycling the router.
Re: Odd TBB test ?
17-02-2017 4:26 PM - edited 17-02-2017 4:26 PM
rongtw: we wanted the MTUs to match to reduce fragmentation. (it wasn't a "fix" more of a test) I've sent your wireshark to Dave to take a look at. I'm not in today but Steve and Dave should be looking.
Ex-Broadband Service Manager
Re: Odd TBB test ?
17-02-2017 4:49 PM
@Kelly thanks i have sent another PM did you see ?
Re: Odd TBB test ?
17-02-2017 6:19 PM - edited 17-02-2017 6:30 PM
try to play BF1 struggling http://www.thinkbroadband.com/speedtest/results.html?id=14873554233596129009
Hopped to gateway psb-bng02. see if that helps
Re: Odd TBB test ?
20-02-2017 10:24 AM
Problems with the performance test are not related to the "new network". It is purely a database issue on BT side with incorrect records following any L2C order placed.
