Odd TBB test ?
SteveA
Re: Odd TBB test ?
10:28:11, 16 Feb. PTM over DSL is down after 61 minutes uptime
10:28:11, 16 Feb. PPPoE is down after 60 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
10:28:08, 16 Feb. PPP LCP Send Termination Request [User request]
Oddly its WAN Ethenet 2 - Down when my Hub1 disconnects like that (and no I wasn't even in the house when it happened ... and the laptop was screen locked so I know it wasn't the cats).
At the moment my speed tests are rock solid so I'm not touching anything 😉
rongtw
Fixes: 12
Re: Odd TBB test ?
I just tried to play BF1 Sad  terrible
gateway pcn-bng01http://www.thinkbroadband.com/speedtest/results.html?id=148725611607097279653
http://www.thinkbroadband.com/speedtest/results.html?id=148725612345378081051
Kelly
Fixes: 9
Re: Odd TBB test ?
Are you able to wireshark that for us?
Kelly Dorset
Ex-Broadband Service Manager
rongtw
Fixes: 12
Re: Odd TBB test ?
@Kelly sorry Sad   i will have to DL wireshark
rongtw
Fixes: 12
Re: Odd TBB test ?
@Kelly PM sent Thumbs_Up
rongtw
Fixes: 12
Re: Odd TBB test ?
getting worse Sad
Kelly
Fixes: 9
Re: Odd TBB test ?
Rongtw: What router do you have, and what is your computers mtu set to?
Kelly Dorset
rongtw
Fixes: 12
Re: Odd TBB test ?
I have a ASUS DSL -AC68 U
MTU set by win10 default settings , will check when home
Kelly
Fixes: 9
Re: Odd TBB test ?
Windows defaults to 1500.  What is it set in the routers menu?  It's on the Internet connection page according to this: http://www.thinkbroadband.com/hardware/reviews/78-asus-dsl-n55u.html
Kelly Dorset
Kelly
Fixes: 9
Re: Odd TBB test ?
If the Asus is 1492 (which is suggested as the max value on that TBB page) set the windows 10 MTU value to match.  (we're trying to eliminate fragmented packets from your tests, and this should help reduce it!)
Kelly Dorset
rongtw
Fixes: 12
Re: Odd TBB test ?
@Kelly  yes just check MTU 1492 Thumbs_Up   will set to 1500
DS
Seasoned Champion
Fixes: 22
Re: Odd TBB test ?
I could be wrong, but I think it's actually referring to the built in modem on the hub one (possibly it's somehow thinking the separate OR modem is in use..?). I've seen the same with nothing connected to the hub via Ethernet - maybe one of the PN guys can clarify what causes the event to be shown in this way....?
DS
Seasoned Champion
Fixes: 22
Re: Odd TBB test ?
It's been a while since I last thought about all of this, but you'd be better setting W10 (if possible) to 1492 - setting to 1500 causes more issues, does it not?
rongtw
Fixes: 12
Re: Odd TBB test ?
i cannot change router MTU max is 1492 , so have set windows to 1492 also .
gateway pcn-bng01. Sad  http://www.thinkbroadband.com/speedtest/results.html?id=14872703361541882141
DS
Seasoned Champion
Fixes: 22
Re: Odd TBB test ?
So in the interest of this thread...
... here's 3 from this morning
11:01 - http://www.thinkbroadband.com/speedtest/results.html?id=1487242874548334255
11:02 - http://www.thinkbroadband.com/speedtest/results.html?id=1487242942181170255
12:20 - http://www.thinkbroadband.com/speedtest/results.html?id=1487247659538729455
(note YV IP channels not in use)
Though I've tried something else (due to the MTU1492 being mentioned), tested at 19:08 but took a while to remove unwanted extras - using 146.xxx.x.xx IP address
(bits removed so it can be posted into the public domain)
i guess this also might help?
