Odd TBB test ?
Kelly
Fixes: 9
Re: Odd TBB test ?
SteveA / rongtw / NoZephy
I think your issues look different to the issues being worked on by Bob and the Team.  In the first problem, the 1x speed tests very extremely slow compared to the 6x:
e.g. https://community.plus.net/t5/image/serverpage/image-id/4094i7342D45DB3AC0872/image-size/large?v=v2&...
I'm having a chat with the guys about it though!
Just re-read the thread and I'm now suspecting it's the same problem, just not as bad.
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
Re: Odd TBB test ?
Of course, it could just be that whatever was causing the extremely slow results is now just causing slow results....
Kelly Dorset
rongtw
Fixes: 12
Re: Odd TBB test ?
@Kelly nice to see you back here Thumbs_Up
the extreme results i have seen cause web to slow down Embarrassed but sometimes my test show only 10-20 drop in speed , but its not any specific  time of day ?Huh
but is still occurring Sad
Kelly
Fixes: 9
Re: Odd TBB test ?
Do you have times of good web browsing/gaming performance alongside good speed tests, and other periods of poor performance and when you run speed tests see the slowdowns?  Is it that cut and dry?
Kelly Dorset
rongtw
Fixes: 12
Re: Odd TBB test ?
@Kelly  yes i would say 80% of the time its fine Smiley but i can tell when its odd
I do get regular test thats ok  http://www.thinkbroadband.com/speedtest/results.html?id=148605089839259686647
SteveA
Re: Odd TBB test ?
148606630716037685415
rongtw
Fixes: 12
Re: Odd TBB test ?
small drop today Sad
Re: Odd TBB test ?
@rongtw - You may want to download this, to save you capturing the whole screen. Just a thought Wink
rongtw
Fixes: 12
Re: Odd TBB test ?
@Anonymous Cheers Thumbs_Up but i wanted to show date and time on capture Smiley
so no one can say i just posting old ones
SpendLessTime
Fixes: 86
Re: Odd TBB test ?
@rongtw
If you just use the URL to the PNG given in the box just below the cut off in your screen grab and use "insert photo" and paste the URL there, then you get this
148616135006420569649
rongtw
Fixes: 12
Re: Odd TBB test ?
BF1 was playing odd tonight  just checked i got this
 http://www.thinkbroadband.com/speedtest/results.html?id=148624678357301846155
SteveA
Re: Odd TBB test ?
its happening this morning on psb-bng03
rongtw
Fixes: 12
Re: Odd TBB test ?
on gateway pcn-bng01. i got this Sad   slight drop again
http://www.thinkbroadband.com/speedtest/results.html?id=148637519014022645258
rongtw
Fixes: 12
Re: Odd TBB test ?
Go on some explain why i keep getting odd speed drops ?
http://www.thinkbroadband.com/speedtest/results.html?id=148664240705554079535
rongtw
Fixes: 12
Re: Odd TBB test ?
and again http://www.thinkbroadband.com/speedtest/results.html?id=148673057710342249308
