Odd Speedtest readings and slowing Upload this morning.
danludlow
I run a speedtest first thing every day (yes I know, paranoid about speed! ^-) ). Normally they don't vary, but this morning it did.
Ping was 97ms (normally 12-20) and downloading saw about 17Mbps on the needle ,which suddenly hit 98Mbps and stayed there for maybe 2-3 secs. 98Mbps is "impossible". Final result, Down, was 34Mbps or thereabouts, Normally its 45Mbps at the PC and 47Mbps at the socket.
Up speeds have been falling over the last 3 weeks from 11.5Mbps to 10.05Mbps. On this mornings test, needle and result topped out at 5Mbps, half of recent.
I restested just now and all figures are back where I expect to see them, but is the slowing Up speed a sign of possible fault or failure?
Any idea why these odd figures occurred? I cannot get all the stats on my line from my router, I'm using an Hauwei BTO Modem to connect to my cabinet. Is there an easy way to know if G.INP is enabled?
Fixes: 239
Re: Odd Speedtest readings and slowing Upload this morning.
I've checked your line and G.INP appears to be enabled as your profile is "0.128M-49M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off"
With regards to the upload sync speed dropping this may be due to crosstalk. It's not enough of a drop for us to raise this as a fault I'm afraid.
 Matthew Wheeler
danludlow
Thanks for looking Matthew. Speeds are good again so all hunkydory, I always worry if I see a speed drop. Had a power cut today of nearly 3 hours. Life without my PC or internet is pretty grim. I do have a smartphone so not entirely in the dark ages, but too close for comfort!
