Nrtwork printer
- Re: Nrtwork printer
Nrtwork printer
09-02-2016 10:51 AM
Very confused! Can I connect a USB printer to my Hub One Fibre Router and share it amongst the connected computers (many!)?
If not - can you suggest a good replacement modem/router that WILL allow such a facility?
Message 1 of 7
(1,347 Views)
6 REPLIES 6
Re: Nrtwork printer
09-02-2016 11:11 AM
No, printing isn't officially supported for the USB port on the hub one.
Message 2 of 7
(1,071 Views)
Re: Nrtwork printer
09-02-2016 11:53 AM
Are you suggesting that unofficially it may work?
Message 3 of 7
(1,071 Views)
Re: Nrtwork printer
09-02-2016 11:59 AM
it may work, have you tried plugging it in and accessing it at \\192.168.1.254 ?
Message 4 of 7
(1,071 Views)
Re: Nrtwork printer
09-02-2016 12:32 PM
Not promising - says 'No devices detected' even after a re-boot'.
Ah well - any suggestions for an alternative?
Message 5 of 7
(1,071 Views)
Re: Nrtwork printer
09-02-2016 12:37 PM
Which printer do you have? Is it only USB?
You could share it via a PC, or NAS if you have one.
Might it be time to upgrade to a Wi-Fi printer?
Message 6 of 7
(1,071 Views)
Re: Nrtwork printer
09-02-2016 12:56 PM
I managed to get a printer networked using the usb port on the TG582n - googled it for instructions. I'm sure there are similar for the hub one, or BT HH5.
My other car isn't a Ferrari
Message 7 of 7
(1,071 Views)
