Nowhere near the minimum speed - please check
adamc93_forums
My minimum speed is supposed to be 60.9Mbps and I'm currently getting between 10-15Mbps.
I've followed the steps outlined here including exposing the test socket.
https://community.plus.net/t5/Fibre-Broadband/Nowhere-near-the-minimum-speed-please-check/td-p/16596...
Are there any other steps I can follow to get my guaranteed speed at least?
7 REPLIES 7
Legend
Fixes: 248
Re: Nowhere near the minimum speed - please check
Welcome to the forums, @adamc93_forums . FTTC connection problems are a little harder to manually fix than ADSL, but sight of your Helpdesk data page, obscuring personal details, and the results from these two links may shed some light: https://www.broadbandchecker.btwholesale.com/#/ADSL -obscuring your personal details, and https://speedtest.btwholesale.com/ making sure you report the advanced test result.
adamc93_forums
Hi @jab1 thanks for the quick reply!
Attached is the results of both. The speedtest.net and google speed tests are lower though.
Legend
Fixes: 248
@adamc93_forums The Availability Checker isn't as helpful as I would have liked - it's a bit old, but not much we can do about that.
Can you post the Help Desk page from your router, and also re-run the speed test, but do the advanced test, please.
adamc93_forums
Here's the help desk info below...
I'm guessing the advanced test is the Additional Diagnostic? (which is just running now)
Legend
Fixes: 248
Your connection speed (to the router) is within your estimated range - so PN/BT won't regard that as a fault. I am assuming this is a wired test?
adamc93_forums
I'm testing over wifi
Legend
Fixes: 248
Can you possibly do a wired test - Wi-Fi results are very unreliable? And your Additional Diagnostics report?
