Not the speed I'm expecting..
- Not the speed I'm expecting..
- « Previous
- Next »
Re: Not the speed I'm expecting..
04-03-2019 12:56 PM
I've updated the support ticket with some time slots.
Regards
04-03-2019 2:09 PM
08-03-2019 11:24 AM
08-03-2019 11:32 AM
08-03-2019 12:29 PM
Hi @RichyBoy,
I have retested the line and checked the engineer notes, they confirm that a lift and shift has been completed but the engineer hasn't provided confirmation that the sync rate is at the maximum achievable.
As the circuit is still testing under the estimates provided on sign up after the lift and shift, I would be happy to add a note to your account confirming the contract can be removed. Just so that you are aware, the other product available is 40/10. If you was to take this product, you would see approximately a 15Mbps reduction in speed and a 10Mbps reduction in upload speed.
Alternatively, as no notes were provided to confirm the maximum sync rate. We could send a further engineer as the profile has been higher and within the estimates in the past but this may not result in achieving the estimates.
Let us know how you would like to proceed.
08-03-2019 1:26 PM
I don't think we should do anything at all for a numbe of days until DLM has had a chance to work properly.
Changing ISP isn't going to solve anything here if fundamentally it's a capacity issue with the infrastructure, I will have to sit tight for a unspecified duration until Fibre reaches the property. I'm not particulary happy with that; I had Virgin several years ago and swapped to Infinity 2 when that became available and that was rock-steady 76 Mbps with none of Virgin's encumbent problems such as shoddy nameservers etc. I swapped to you guys because I noticed I may has well have been on the cheaper Infinity package as my synch speed had dropped to around 60 Mbps. I would be very unwilling to go back to BT as a ISP and I believe the regulator should be throwing them under the bus for this kind of practice, that's my opinion anyway.
if somebody said "here's a sign up page, it will cost £2K, but we'll get Fibre to you within 3 months" i'd be chomping.
30-03-2019 3:48 AM
So, as of 30th March:
5. DSL uptime: | 0 days, 02:38:08 |
6. Data rate: | 20000 / 51456 |
7. Maximum data rate: | 22864 / 60427 |
8. Noise margin: | 6.5 / 6.3 |
9. Line attenuation: | 14.6 / 15.8 |
10. Signal attenuation: |
14.5 / 15.8 |
Dropped even further!
Obviously not a PlusNet issue per se; but this should not be happening.
I was very concerned withthe quality of the last OpenReach engineer that was sent around - told me there was fibre into the building (there isn't), insisted I should run a filter and replaced the face plate with a 5c mk 4 (why ? I have no phones or extensions wired up).. said he was going to snitch on the last engineer that was around because of it...
Bear in mind this was syncing quite happily at 71 Mbps with DLM - what has happened ? The original defect I think is answerable in so much as the phone had a weird tone on it, due to lack of termination according to the engineer (possibly as the last previous one moved me of the blue pair onto something with a lower error rate).
Not happy.
30-03-2019 10:11 AM
Hi @RichyBoy
Thanks for coming back to us - I'm sorry to hear that this has dropped further since we last spoke - I've also noted your feedback in terms of the engineer and will feed this back.
Just going back to @Jubby's previous post, we're still looking at the same options in terms of moving this forward - just let us know how you want to proceed and we'll get on it.
Best wishes
Dave
01-04-2019 1:25 AM
I think it is worth sending an engineer around again - I realise ultimately it may make no difference. When I first raised an issue the router was on an extension getting 60 Mbps - and now all I have is the master socket with not even the extension wired, on the test socket, and getting 51 Mbps. The performance degredation is in their terrirtory; not mine.
01-04-2019 10:05 AM
01-04-2019 9:40 PM
I've updated the case with some dates/times
Regards
01-04-2019 9:50 PM
- « Previous
- Next »
