Not received upload speed increase yet,,, can anyone help?
Reedweaver
I was sent an email back on Oct saying I would see an increase in upload speeds. but I only get the following:
Downlod - 17Mbps
Upload 1.4Mbps
Do I need to email anyone?
Reedweaver
Re: Not received upload speed increase yet,,, can anyone help?
Fixes: 106
You've already been upgraded.
The fact that you're only synchronising at 1.4mbps suggests that your line isn't capable of any more. Having said that, your downstream speed is below the handback threshold so it might be worth your time opening a fault ticket to see if we can get your speeds any higher.
Reedweaver
Many thanks, I have raised a ticket. Here are the results from the speedtest.
