Not really a problem as such but....
St3
Aspiring Champion
Fixes: 4
My parents have been on FTTP Trial for well over 2 years now and so far so good, they normally have 37/19 but i noticed over the last month their upload speeds have reduced and now they have 37/6 So just wondering why the big drop in upload speed ?
Should we report is as a fault or does the profile need a nudge ?
Speedtest below
My Broadband Speed Test
Fixes: 162
Re: Not really a problem as such but....
We removed the 40/20 product quite a while back, so it may have been the move to 55/10 that's caused it. Can you PM me their username and I'll take a look.
 Chris Parr
 Plusnet Staff
St3
Aspiring Champion
Fixes: 4
ok message sent
Fixes: 162
Looks like the upload speed is above the speeds they should be getting St3 as per this post:
https://community.plus.net/t5/Fibre-To-The-Premises-trial/when-will-they-be-able-to-get-fibre/m-p/12...
 Chris Parr
 Plusnet Staff
St3
Aspiring Champion
Fixes: 4
I just dont understand how they can have 40/20 package from day one for almost 2 years and then the upload speed is capped at 6 meg it makes no sense to me.
Fixes: 162
We haven't made any changes, so they've had faster speeds than signed up to for 2 years!
This may get restricted to 40/2 at some point in the future too if a data cleanup on the FTTP products is performed.
 Chris Parr
 Plusnet Staff
St3
Aspiring Champion
Fixes: 4
So when you do this data cleanup it will push them back to 40/2 for good ? What is a data cleanup btw ive never heard of that before.
Fixes: 162
If it gets picked up on a data cleanup it would match the wholesale product to the one the account should be set on yes.
I'm not making any changes to this so they'll continue with the same speeds they're getting for now.
 Chris Parr
 Plusnet Staff
St3
Aspiring Champion
Fixes: 4
ok nps well thanks for checking it over for us.
