Not getting promised speed....
borosilverback
Promised 34 min - initially got 17 but thought the first few days id leave it as when i spoke with an advisor i was told my speed would vary initially,now im only getting 8 if im lucky - plus the connection feels unstable - when i do a speed test the needle jumps about as if the connection is erratic,ive plugged in via ethernet and its better,but the wifi isnt up to much - my old provider had a much faster connection,and i cant help but feel dissapointed initially,this isnt exactly firbe speeds...
Animegav
Re: Not getting promised speed....
If it's less than the handback threshold then you're free to leave without penalty if it doesn't improve.
rongtw
Fixes: 12
Hi , put you phone number in here should show what is possible Thumbs Up http://dslchecker.bt.com/
borosilverback
thanks - its well under - pretty [-Censored-] poor to be honest.
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
Fixes: 189
Sorry to hear you're having speed issues.
I've tested your line and it's not showing any issues as shown below.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 530.1
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2017-10-01T14:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 39.9 Mbps 40.0 Mbps 39.9 Mbps
Up Stream Line Rate 1.9 Mbps 9.9 Mbps 6.9 Mbps
Up Time 0.0 Sec 900.0 Sec 868.0 Sec
Retrains 0.0 54.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-10-14T12:37:04Z 2017-10-14T12:52:04Z
Ingress Code Violation 0 0
Egress Code Violation 2 0
Errored Seconds 2 0
Severely Errored Seconds 0 0
Unavailable Seconds 0
Are you testing over a wired or wireless connection?
 Matthew Wheeler
borosilverback
Tried both.....with a cable it was as promised around 36....but the wireless seems erratic and slow however I’ve just re tested on iPhone it and it’s 34.....so provided it stays at that I’ll be happy.
Fixes: 385
If your speed drops again over WiFi but remains solid using a wired connection, I'd recommend taking a look at this guide about wireless connectivity: https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
