Not getting advertised speed
Derath
Hi all, got new connection up and running on October 5th and it was running at ~ 35 mb/s on wifi so I assumed it was slow because of a combination of the usual tick up in speed over time and the wifi however I just switched to wired and i'm still only getting 35 mb/s on speed tests.
Double checked my order definitely says fibre extra and expected speeds between 66-80 with a minimum of 61 so If i was guessing i'd assume i'd been put on the regular fibre package by mistake, can someone check out if thats the case? I had all sorts of trouble with my order anyway so wouldn't be surprised if it got messed up in the process.
Fixes: 37
Re: Not getting advertised speed
Hi @Derath,
I'm sorry that your speed has been poor since your connection was set up at your new property. I've checked and unfortunately you have been incorrectly provisioned on standard up to 40mbps fibre rather than on fibre unlimited. I'm very sorry for this error and I have passed feedback on to our provisioning team.
I've placed a modify order to move you onto the correct fibre package now and this will complete within two working days, so by midnight on Tuesday at the latest. Please reboot your router if you don't see an automatic increase in your speed after this time.
 Emily D
Derath
Hi @EmilyD
good to get confirmation I guessed that was the case as aside from the speed the connection has been stable and performing well so seemed likely it was a setup error of some kind, thanks for the swift response even at the weekend i shall follow your instructions and hopefully its fixed shortly.
Derath
as an update i'm Still only getting 36-38mb, I've restarted the router several times as the deadline was supposed to be tuesday midnight but still no changes, any ideas? This is getting frustrating
Fixes: 76
Hi there, I've just updated the connection profile on your account so you should hopefully see some improvement now.
 Adam Walker
Derath
Excellent up to 64 now which is much closer to what I was expecting, thanks for your help.
Fixes: 76
Ah that's great to see, cheers for the update and it's no problem at all!
 Adam Walker
