Not Getting Download Speed As advertised.
TONKA_777
I am on the supposed 62-72mb Unlimited Fibre Extra package and I am getting no where near that.
On te BT wholsale speed test 16.90mbps download and 20.70mbps upload.
I have spoken a couple of times on the phone to plusnet tech and have seen no improvement.
All my equipment is wired connections using ethernet, smart tv and desktop pc.
I have disabled all firewall/anti virus software and retested to no improvement.
Not very impressed.
Anyone got a solution?
15 REPLIES 15
TheMightyAJ
Fixes: 105
Re: Not Getting Download Speed As advertised.
Hi @TONKA_777,
Sorry for any inconvenience this is causing. Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net.
 Alex H
TONKA_777
Can you get one of your tech guys to look at this info please.
This is on a wired connection, plugged into a mk4 openreach master socket with a 50cm ADSL shielded lead, no other extensions anywhere or ancilliary wiring.
The connection is very laggy and makes some websites unusable.
Is this normal?
Stats
Stats recorded 11 Aug 2020 12:37:33
DSLAM type / SW version:	BDCM:0xc190 (193.144) / v0xc190
Modem/router firmware:  	AnnexA version - A2pvfbH043q.d27b
DSL mode:               	G
Status:                 	Showtime
Uptime:                 	38 days 17 hours 48 min 56 sec
Resyncs:                	0 (since 10 Jul 2020 20:29:31)
				Downstream	Upstream
Line attenuation (dB):  	35.0		0.0
Signal attenuation (dB):	35.0		0.0
Connection speed (kbps):	219500		41739
SNR margin (dB):        	3.3		3.2
Power (dBm):            	0.0		4.0
Interleave depth:
INP:                    	550.00		535.00
G.INP:                  	Not enabled		Not enabled
Vectoring status:       	Unknown
RSCorr/RS (%):          	261.8057		0.4914
RSUnCorr/RS (%):        	0.0000		0.0000
ES/hour:                	1.05		0
connspeed
es
crc
These are the speed tests from https://www.thinkbroadband.com/speedtest
Date/Time Avg Down Avg Up Provider
11-08-2020 11:50:23 (GMT) 36.3 Mbps 2.5 Mbps Plusnet
22-07-2020 14:03:56 (GMT) 38.0 Mbps 1.6 Mbps Plusnet
22-07-2020 14:03:15 (GMT) 40.3 Mbps 16.1 Mbps Plusnet
22-07-2020 14:02:35 (GMT) 32.3 Mbps 2.9 Mbps Plusnet
22-07-2020 14:01:59 (GMT) 34.8 Mbps 3.1 Mbps Plusnet
22-07-2020 13:58:53 (GMT) 22.4 Mbps 1.9 Mbps Plusnet
22-07-2020 13:57:56 (GMT) 37.2 Mbps 2.7 Mbps Plusnet
22-07-2020 13:54:53 (GMT) 27.9 Mbps 1.8 Mbps Plusnet
22-07-2020 13:54:18 (GMT) 29.2 Mbps 1.8 Mbps Plusnet
tinytaco
Fixes: 29
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
 Noor
Browni
Aspiring Hero
Fixes: 52
Why have you included stats from my router here?
Ex-Plusnetter now living life in the G,fast lane!
Marksfish
Seasoned Pro
Fixes: 4
Why is the TBB graph showing Zen?
Browni
Aspiring Hero
Fixes: 52
@Marksfish it's my graph!
Mustrum
Fixes: 61
They are not very good speeds for G Fast !😀
Why is he showing your stats?
Have you reported this?
At least a breach of forum rules - but is it a lot more serious?
TONKA_777
Apologies, posted wrong info.
Could a mod rectify the post by deletting Brownis graphs please?
Strat
Fixes: 554
Post edited. Anything else, let me know.
Customer and Forum Moderator. Windows 10 Firefox 96.0.2 (64-bit)
TONKA_777
Thank you.
TONKA_777
Live Monitor of my connection.
5b68bf3bc746c70086a204e57165b72678707714
Mustrum
Fixes: 61
That is a pointless graph - it shows TBB is not able to ping your router which is normal.
There are ways around this, if you read the help pages on TBB.
TONKA_777
Have you a link please?
Mustrum
Fixes: 61
No I don't have a link to your TBB graph, I presume you do.
All you need is to go to that and scroll down!
