Not Fibre Extra
Not Fibre Extra
Hi, I was supposed to get Unlimited Fibre Extra today however after a look at the router settings it seems that I'm only on the slower fiber package. Can someone please fix this for me?
UPDATE : After a call to plusnet this has been raised as a fault and I should get a call from the fault team in no more than 72 hours.
6 REPLIES 6
Seasoned Champion
Fixes: 29
Re: Not Fibre Extra
I think it's PlusNet's fault.Angry They have ordered the wrong product. Should be able to re-order and get it upgraded by tomorrow. Hopefully one of the forum staff will be able sort this for you.
Re: Not Fibre Extra
Yes. Hopefully this will be fixed soon.
will let you know how long it takes. Smiley
Fixes: 964
Re: Not Fibre Extra
Hi Martin,
Sorry to hear you're having speed issues
I've rectified this for you now.
Can you let us know how your speed looks tomorrow?
Re: Not Fibre Extra
I've just checked the router and it says that I'm getting
Up: 60.92Mbps
Down: 13.44Mbps
will this speed up to the full 80/20 by the end of the day?
Thanks.
Re: Not Fibre Extra
Still not at full speed yet. will try again tomorrow.
Fixes: 964
Re: Not Fibre Extra
From looking at the estimates of your line, the speed you're getting is on target.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
  High Low High Low
VDSL Range A (Clean) 80 60.2 20 18.7
It's an up to 80/20 service. Actual speeds can vary, depending on expectations of your line.
