Noob Fibre uprage enquiry
IVYDEAN39
Apologies for my ignorance  Embarrassed
I currently have broadband through Plusnet, I presume if I upgrade to unlimited fibre extra.
Does this come through the existing BT phone line or will I require addtional installation work by an engineer?
Fixes: 62
Re: Noob Fibre uprage enquiry
it comes through the existing phone line
note - don't do it through the upgrade process - phone customer options - I am thinking of leaving and see what they will offer if you are going to move your phone across
HughPH
FWIW I went from £9.99/month for ADSL to £10/month for VDSL. I extended my contract term to 24 months because PlusNet's customer service is not nearly as shabby as other operators.
IVYDEAN39
Thanks for the info chaps  Wink
VDSL is fibre i'm guessing - what speed did you get 17mb, 38mb or 76mb for £10pmth?
HughPH
Sorry, yes, VDSL "is" fibre. In fact if you want to get nerdy, it's fibre from the exchange to the cabinet and then VDSL from the cabinet to your house. VDSL runs over the old copper lines and is related to ADSL.
We're 1 mile from our cabinet so we can only get up to about 28Mbps (sync - download is about 25.5Mbps at best) so I went for 38Mbps with a 2Mbps cap on upload speed. Our upload speed would only go up to 4Mbps uncapped anyway.
IVYDEAN39
Im getting these figures - I presume I can go for 76mb and get near that figure?
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 80 68.7 20 20 -- Available
FTTC Range B (Impacted) 75 41.2 20 14.9 -- Available
ADSL Max Up to 8 -- 7 to 8 Available
Fixed Rate 2 -- -- Available
Other Offerings
FTTP on Demand 330 30 -- Available
Fibre Multicast -- -- -- Available
HughPH
You can get between 41.2 and 78 - there's no saying what it would actually be. If you're getting a good rate on ADSL (e.g. 24Mbps) then you should also get a good rate on fibre.
scottymc
Mate if  I had your options , scratch FTTC and get FTTP 330 meg download and 30 meg upload.... 
Fixes: 222
Fttp on demand costs a small fortune
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
scottymc
There's always a down side.......
adie:quote
IVYDEAN39
Quote from: scottymc
On Plusnet I am currently obtaining d/l speed of 2.62M/bs  Angry
Time to look into FTTP 300 - bother the cost!  Cool
Fixes: 100
I've seen figures of £150 per month plus a large installation bill Shocked
Customer and Forum Moderator.
scottymc
That's a bit on the steep side......
IVYDEAN39
http://www.directsavetelecom.co.uk/ftth.php
Broadband & Voice* 300Mb 30Mb Anytime 3 Months FREE £48.50 £5.50
Is this is a fttp deal?
Fixes: 62
yes but only where you can get it - have you checked your site as it is very limited
