Non Plusnet Ethernet switch
FIXED- Subscribe to RSS Feed
- Re: Non Plusnet Ethernet switch
05-09-2019 6:14 PM
Hi all
I currently have a plusnet network switch with a separate OpenReach 'modem' (I know it's not really a modem but you know). I have YouView TV as well. I have managed to run out of ethernet ports at the back of my PlusNet box and want to get somthing like this:
TP-Link TL-SF1008D 8-Port 10/100 Mbps Desktop Ethernet Switch
Would there be any problem using this?
Thanks ppl
Fixed! Go to the fix.
05-09-2019 8:51 PM
Hi pete_uk,
The Ethernet switch will work with the PN router.
You will not have any problems.
Just plug one of the switch Ethernet ports into a router Ethernet port and the client Ethernet devices into the switch ports.
It should literally be 'plug and play'.
Regards
Richard
