Noisy router 5GHz
- Noisy router 5GHz
Noisy router 5GHz
17-08-2018 1:33 PM
Hi, I have an issue with my router (believe this is a known issue with the Plusnet router) where it is very noisy at 5GHz, can be resolved by only using 2.4GHz but this seems to halve my data rate from ~30Mb/s to 15Mb/s.
I'd like a new router as mine is clearly faulty, any advice on how to go about arranging this?
Message 1 of 2
(541 Views)
1 REPLY 1
Re: Noisy router 5GHz
17-08-2018 2:33 PM
Hi There, Thank you for getting in contact I am sorry to hear of the issues that you are having. I have got the replacement router arranged for you. Just to make you aware this can take 3-5 days to arrive.
Message 2 of 2
(521 Views)
