No wifi but ethernet fine
jefnerf
Hi there, I have a plusnet technicolour TG582n with fibre optic internet.  Today came downstairs to no wireless. Have plugged ethernet in and laptop running fine off the ethernet.  However when I try to log into the router on 192.168.1.254 get a "Access Error: 500 -- Internal Server Error" message.
I have tried pin reset, but wireless still dead.
Any ideas?  Thanks in advance.
7 REPLIES 7
Fixes: 417
Re: No wifi but ethernet fine
1. Take out a new contract and get Plusnet to throw in a new router for £7.99. You may be lucky and get a good one.
2. Go onto Ebay and spend around £20 on a Smarthub 6 and set it up on your Plusnet account. See https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
witherford
Sounds like their may be a hardware fault with the router? how old is it?
If you want to arrange a team viewer session i would be happy to have a look and see if i can access the router.
Fixes: 1,600
Hi there.
Can you try pressing the WiFi button on the top of the router to see if that brings it on?
Failing that before deeming the router faulty, I'd then recommend try a factory reset by pushing a paperclip into the reset pinhole at the back for 15 seconds.
Let us know how it goes.
southerner
Might sound really daft but have you tried unplugging & plugging the router back in? Just thinking the Wi-Fi side of things may have just crashed.
newagetraveller
"If you want to arrange a team viewer session i would be happy to have a look and see if i can access the router."
No doubt the intention is good, but I would never, ever allow anybody to have external access to my device(s).
jefnerf
Hi all,
Thanks for the replies.  I have done a factory reset, tried turning it off and on etc.  Does seem like the wifi is dead 😕 have had it for nearly 5 years so to be expected!  Will look at new contracts Smiley
EDIT: Have managed to access router via 192.168.1.254 on a different computer and can see in the logs "LOGIN wireless station [a0:63:91:bb:d1:29] can't get authorized."
Fixes: 1,600
Cheers for getting back to us,
It does sadly seem that way (RIP @jefnerf's Technicolor router)
Let us know if you need any further advice or assistance.
