No usage info
Grezzer36
No usage info
For PNet:  :  My a/c is showing nil usage from 31st March, obviously incorrect. Don't know if anything to do with this: HH5 lost sync briefly approx. 5.30pm on 30th March. Could this have put spanner in works re usage? Undecided
Fixes: 236
Re: No usage info
That shouldn't have caused any issues.
I'll have a word to see if there's any issues that I'm not aware of.
 Matthew Wheeler
Grezzer36
Re: No usage info
Thanks Matthew. Everything seems to be working ok just usage stats show 0kb every day from 31st march.
Fixes: 5
Re: No usage info
Matt mentioned this earlier, but I'm not sure of his findings. Hopefully, we'll get this sorted quickly for you.
 Tony T
BlackPearl
Re: No usage info
Why would you be hopeful of fixing this quickly ?
I have had no usage stats since I joined in November even after raising
2 tickets and pointing it out on the forum.
Re: No usage info
Like here
http://community.plus.net/forum/index.php/topic,137549.msg1216641.html#msg1216641
Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Grezzer36
Re: No usage info
Usage stats back on line last Fri (10th). Dont know why but seems ok now. Still 10 day period showing nil usage for some reason. But alls well for now. Smileyl
