No speed change since upgrade to fiber plus
rhourahane
I've upgraded from fiber to fiber plus on Monday and while my upload speed is now around 18Mbps there has not been any change to my download speed from 52Mbps.
According to the email when I ordered the upgrade I should be getting at least 61Mbps and possibly up to 80Mbps.
Do I need to wait for the line to speed up or should I get the increase in speed immediately?
If the increase should be instant what to I need to do get my promised speed improvement?
I it matters I've go a openreach modem and technicolor 528n router.
Fixes: 311
Re: No speed change since upgrade to fiber plus
What are the ranges listed when you enter your phone number here https://www.dslchecker.bt.com/ ?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
rhourahane
Here is the results:
Telephone Number xxxxxxxxxxx on Exchange HIGH WYCOMBE is served by Cabinet 82
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 69 20 19 61.4 Available -- --
VDSL Range B (Impacted) 80 63.2 20 19 49 Available -- --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 11 -- 10 to 12 Available -- --
WBC ADSL 2+ Annex M Up to 11 Up to 1 10 to 12 Available -- --
ADSL Max Up to 5 -- 3.5 to 7.5 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
G.fast Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 20-04-2018
Fixes: 311
Couple more things to check.
What is your current line speed here https://www.plus.net/my.html?action=data_transfer_speed
and the results of a speed test from here. http://www.speedtest.btwholesale.com/
rhourahane
Here is the out put from the plus net page:
    Telephone number:xxxxxxxxxxx
    Phone exchange:HIGH WYCOMBE
    Estimated line speed:80Mb (This may vary between 66Mb and 80Mb) - Checked on 2017-12-10 20:57:19
    Current line speed:80 Mb
Can't run the speed test now as I'm at work, will run it this evening.
rhourahane
After rebooting both router and modem the BT speed test gives the following:
If I run the speed test from http://www.mybroadbandspeed.co.uk I get the following results:
Which is much more like I was expecting. It would be nice for it to be a bit higher but at lest its an improvement.
Not sure what is going on with the BT speed checker.
Browni
Aspiring Hero
Fixes: 47
Are you using Firefox by any chance?
There's a thread here about the BT Speedtest misbehaving.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
rhourahane
Yes I'm using Firefox. Running in IE gives much better results 62.81 up and 15.09 down
Fixes: 487
Hi there.
I'm sorry to hear you're experiencing speed problems.
Whilst our tests are showing your router in sync at 66.9mbps they're also flagging a potential line fault so I've raised this through to our suppliers now. We'd expect this to be investigated within 3 working days.
