No reply for plusnet support in a week
spudy12
Have seen my internet speed halved in last month.
emailed support on 8-12-2015 and have not heard anything back since.
what the hell is going on?!
Fixes: 10
Re: No reply for plusnet support in a week
If you emailed support the answer to your question is nothing!
There are no monitored support mailboxes. If you have a fault you need to raise it by going through http://faults.plus.net
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Plusnet Staff
Plusnet Staff
Fixes: 159
Sorry for the delay in responding, I can see the fault has been investigated and passed through to BTWholesale, we're awaiting an update from them at the moment with the next steps.
 Chris Parr
 Plusnet Staff
