No internet
FIXEDTopic Options
- No internet
23-06-2018 10:06 AM
I've had no internet connection since around 9 o'clock last night, on my router it's been an orange light with an orange symbol and sometimes red, manage to get a blue light this morning but no device in my house will connect to the internet it just says I need to sign in to the router and when I do I still have no internet connection, I feel like I've exhausted all options now
Fixed! Go to the fix.
Message 1 of 3
(684 Views)
2 REPLIES 2
Re: No internet
23-06-2018 11:01 AM
Has anyone got any ideas it's just constantly asking me to sign in I've restarted the router several times, reset it, turned it off and on, checked all the cables
Message 2 of 3
(669 Views)
23-06-2018 1:36 PM
Hi there.
It looks like your router is trying to connect with the wrong password.
If you can factory reset your router once more by pushing a paperclip into the reset hole at the back for 20 seconds you should be back online shortly after.
Message 3 of 3
(646 Views)
