No internet this morning AGAIN
- No internet this morning AGAIN
Re: No internet this morning AGAIN
18-03-2015 12:39 PM
18-03-2015 12:56 PM
18-03-2015 2:22 PM
Quote from: AndyH Your upload might be on a banded profile. Only Plusnet can tell if it is or not when doing a line check.
Hopefully it will get there.
18-03-2015 2:26 PM
"0.128M-67M Downstream, Interleaving High - 0.128M-19M Upstream, Interleaving On"
Interestingly our tests are still showing a external issue with the line affecting the connection.
We can raise this and see what happens. Hopefully the upload will go back to where it was before.
18-03-2015 2:30 PM
18-03-2015 2:44 PM
18-03-2015 2:49 PM
19-03-2015 12:43 PM
I told him about my upload speed problem & he said it could be PN have capped that or you are on a certain % of d/load & upload,maybe PN need to look at that.
Anyway this is my latest speed test,it may come back up further yet,i will monitor it for a while.
19-03-2015 1:15 PM
The upload sync is at 6.4 now which is a slight increase but I'm not sure if we can get it higher
19-03-2015 1:20 PM
Is it possible to explain how it was higher before the complete failure of the line and the subsequent repair? See the speed test in the user's sig.
Kevin
19-03-2015 2:18 PM
19-03-2015 3:41 PM
I suspect at some point during the phone fault a different pair has been used and that the one the OP is on isn't as good. We can look into getting this changed but it would require a appointment and there's no guarantee the speeds would go back to what they were
19-03-2015 4:09 PM
31-03-2015 10:43 AM
31-03-2015 11:13 AM
any way G.INP is currently being rolled out ( soon for ECI fibre cabs which i'm on ) so that may help if it is indeed part of a rein / noise issue and there is vectoring to follow so it may all end up well in the end it's just a waiting game.
