No internet connection, strange dial tone
craighughes16
My fibre connection has been down since yesterday evening, about 8:30pm. The dial tone I hear when I pick up the phone alternates between 2 difference frequency sounds, perhaps once per second. The phone works though.
This is odd behaviour and the first significant issue I've had for years. I've raised a support ticket, but heard nothing yet. Does anyone know what this might be caused by, and whether there is any way for me to get online?
Exchange: SLBWH - Barrow On Humber.
Edit: Apologies, I've just seen there is another forum for fibre broadband. I don't see a way to delete or move the post though.
Fixes: 247
Re: No internet connection, strange dial tone
Do you have voicemail switched on? That results in a different dial tone, though wouldn't impact your broadband.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
craighughes16
I don't know to be honest, we don't use the landline. I just checked for troubleshooting a thought it sounded odd so assumed it was a fault.
I've never heard the dial tone do it before, but the last time I used that phone may have been before I switched to PlusNet Residential (previously on Business).
Fixes: 205
If you can PM me your username I'll get this looked into.
 Matthew Wheeler
craighughes16
Thanks, I've PM'd you.
Fixes: 33
Why not just dial 1571 and see if you a voicemail?
craighughes16
I wasn't at home when I posted so couldn't. I actually had no idea that was how you checked voicemails on a landline - grown up with mobiles and only have a phone line for broadband!
I had a voicemail, the dial tone has gone back to normal. Thanks for your help, just the broadband to sort now :-)
craighughes16
It's working again now. Thanks to all those that helped.
