No internet after 100 session exceeded message
- No internet after 100 session exceeded message
3 weeks ago - last edited 3 weeks ago
Above the '100 sessions message',
"Click on Advanced Settings
Login with your admin password from the back of the router
Click on Continue to Advanced Settings
Select Broadband from the option above
Click Disconnect
Change the username to YourUsername@plusdsl.net
Change the password to your account password
And then click Connect
This should do the trick.
Had to reset the router as it stayed red. Now back to blue but still no WiFi.
Plus when I try to connect using my smart phone it keeps asking for sign in. Which I do but still nothing.
Re: No internet after 100 session exceeded message
3 weeks ago
Hello, a warm welcome to the forums.
A key question - have you received a SMS (or other communication) advising that your service with Plusnet has been activated?
The resolution you describe (and the smart phone experience) suggests that the router does not have the correct user name and password for the broadband service, or your account has not been (fully?) activated. If you have been advised that the service has migrated and that the account has been activated, then in the first instance you should follow the instructions for resetting the router.
Are you on an ADSL (broadband) or a FTTC (fibre) service? Were you on the same type of service with TT? There are additional complexities in switching from LLU suppliers to pure BT based services. Sometimes BT forget to make key changes in the exchange. Do you have a dial tone on the phone line? If you dial 17070 does it correctly report your phone number?
3 weeks ago
I received a confirmation email saying broadband is ready "Your fibre broadband's ready to go". I've checked the phone line as you suggested and there is a dialing tone.and I also tested using the number you suggested. I was on fiber with TT and switched to fiber. Admin pw was not accepted when I tried connecting firestick, not box has an orange light even after turning it off.
3 weeks ago
Your account / dsl password which needs to go into the internet settings in the router but should auto configure after a factory reset. Does your account password contain any special characters. I seem to recall that the BT routers (HH5a in Plusnet livery) dislike some permited characters in passwords.
There is the Wi-Fi passcode which is required to connect devices to the router (which is not the same as they connecting to the internet).
Then there is the router admin password which is required to access the configuration screens in the router set up on 192.268.1.254
If connection attempts are broken Ning up a password page then that suggests that the router has not established the PPP session which requires your dsl / account ID and password.
If auto configuration has failed you will need to log in to the router and set them up manually as per the enclosed documentation.
3 weeks ago
3 weeks ago
@Fossil - yes you can, but obscure any 'personal' information - this is an open forum.
3 weeks ago
This topic has been moved from ADSL Broadband to Fibre Broadband.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
3 weeks ago
3 weeks ago
3 weeks ago
3 weeks ago
It is not clear what / where this issue was being encountered, but elsewhere it has been reported a few times - see Solved: 100 Sessions - BT Community and Sessions number....what does it mean - BT Community - it somewhat looks like an internal issue with the BT HH5a routers. See also SOLVED No more than 100 sessions allowed.... - Plusnet Community
It is also not entirely clear from your descriptions "WiFi was / was not working" if you really meant that the WiFi was not working (completely unable to connect to the WiFi network and access the router) or if you simply meant that you could not connect to the internet. All too often people say their wifi is not working, when in fact it is the broadband uplink which is not working.
The solution you describe points to the broadband log in to Plusnet not self configuring correctly. If the router still has the default account name, it will not make a proper connection to the internet. Why that gives rise to the 100 session message is not clear, it implies that the router has got itself confused internally.
