No internet access when TCP/IpV6 enabled on windows PC
This is almost certainly a PC or internal network issue - just looking for help.
I have a PC connected via TP link power line units to the router. It refused to access the internet until I had disabled TCP/IP v6 in the network adapter settings. With that disabled it works fine. I can leave it that way - but I'd like to understand what is going on.
If V6 is enabled - I can still access internal network resources such as network drives.
Wrighty11
Re: No internet access when TCP/IpV6 enabled on windows PC
Hey tonyAtplus,
Happy to hear you managed to sort it. I am aware of the same kind of issue with Mac OSX but no idea of why it happens.
I can only imagine it be due to our network not supporting IPV6 yet your computer might be trying to connect through it when the option is enabled, when it does it just wont let you get online until disabled.
I don't think it is that - because I only recently had this problem.
Fixes: 387
Quote from: Wrighty11
Hey tonyAtplus,
only with very few routers - one of which appears to be the new Sagecom one. You need IPv6 enabled in OS X for Airport Utility, for example.
never had this problem myself , though never used a PN router for wireless either Roll eyes
My Broadband Ping - PN-Fibre
I'll have a play some more over the weekend.
