No email or text and still no broadband
Lel2009xxx
My phone line is connected and BT engineer said broadband is all ready to use. How long does it take for plus net to activate broadband. I moved into my property at beginning of March.
Fixes: 162
Re: No email or text and still no broadband
Your orders are complete, I'm just finishing activating your account now and you should receive the updates shortly about this.
 Chris Parr
 Plusnet Staff
Lel2009xxx
Fantastic Chris, thank you so much. I might get peace at last from my very bored 15 and 9 year old who feel as tho civilisation has ended lol
Fixes: 162
If you follow the setup guides, plug your router in and you should be good to go!
Don't forget that you can now marked as 'fixed' and add thanks directly by clicking the buttons below my post.
 Chris Parr
 Plusnet Staff
Fixes: 162
Hi again, looking at your account you are trying to connect with the wrong password in the router. You can either manually log in to the router to change this, or factory reset the router and it should automatically set up.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 117
Following on from Chris' post, if you're using the Hub One and it still rejects your password, try changing it at https://portal.plus.net/forgotpassword/ and then reconnecting with the new password.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
