No broadband usage being reported
kmw350
I know others have reported that they have their broadband usage reported as '0', but mine is completely blank.
All I get is a message saying 'perhaps you are a new user or it is a new account'. I did change from ADSL to fibre in November but surely it should be showing something by now?
Also, is there anything I can do to check my historic use, or is that lost when I moved to fibre?
Thanks for any answers Smiley
32 REPLIES 32
JayG
Fixes: 6
Re: No broadband usage being reported
I believe that the current situation is that the usage meter has been in effect switched off for everyone other than those on usage limited tariffs because it was involved with packet loss problems for those transferred to the new PlusNet network, and it affects both ADSL and fibre customers.
So, it's on the 'to do' list but not very high up it one suspects.
rongtw
Fixes: 12
It does actually work if you have a Fixed IP Wink
nadger
@rongtw That could explain why mine has been working since start of this account period.
Mustrum
Fixes: 60
@rongtw not for me ! Sad
kmw350
Understood, thanks for all the replies, I'll look out for it reappearing in the future.
SpendLessTime
Aspiring Hero
Fixes: 82
rongtw
Fixes: 12
@SpendLessTime @Mustrum thats odd ?? its always worked for me
Browni
Aspiring Hero
Fixes: 52
I've got a static IP and the usage figures stopped bring recorded on 29/30th December
Ex-Plusnetter now living life in the G,fast lane!
SpendLessTime
Aspiring Hero
Fixes: 82
It stop last year just after I was moved off the AG gateways at Telehouse North and hasn't been active since. Plusnet have disabled accounting across selected gateways for unlimited accounts since November 2016 so it is to do with gateway not IP type. Waiting for the fix!
rongtw
Fixes: 12
well i dont know what it is ?  i have a static on 80/20 and do regular gateway hops But i always see my usage ?
Strat
Fixes: 538
Static IP 80/20 and no usage showing since the 18th of Jan 2017
Don't normally gateway hop but just done it out of curiosity.
Customer and Forum Moderator. Windows 10 Firefox 94.0.2 (64-bit)
SpendLessTime
Aspiring Hero
Fixes: 82
Last night I had to reboot my router as for some reason although every light was green and the router and ONT were up, I could get no internet traffic (TBB ping chart red too). So I ended up being moved out of Colindale to Southbank specifically
.psb-bng01.plus.net (84.93.253.102)
And this morning I now have usage again.
 Prior to this I have had the "Wait up to 4 hours" text in the usage webpage.
alastairmonk
I do have usage limits but currently don't have any daily usage showing.
SpendLessTime
Aspiring Hero
Fixes: 82
@alastairmonk
If you are on a tariff where you have only a limited amount of GB per month AND your usage figures are empty then you need to report it as a fault. Because Plusnet will still charge you for any extra you use even if you cannot see your own usage.
