No broadband following first time setup
sjohnson
My activation date is today and I have received the email telling me it has been activated. I've followed the steps in the setup guide and gone into router settings to log in but I'm still left with an orange light and orange b light. It also says on the router settings internet disconnected.
I've entered my account password correctly but doesn't seem to change anything. Any help would be appreciated
7 REPLIES 7
Legend
Fixes: 254
Re: No broadband following first time setup
Welcome to the forums, @sjohnson . It can take up to midnight of 'activation day' for all the network components to 'mesh'.
When you enter your account name 'xxxxx@plusdsl.net' and password, the DSL cable needs to be unplugged, and reconnected after you have clicked the 'save' button.
sjohnson
Thanks for the reply. I've given this a go and it doesn't seemed to have helped.
Legend
Fixes: 254
If you have no connection tomorrow morning, post back and we can investigate.
NOTE: I'm not PN staff, but know my way around. 😉
sjohnson
Okay thank you. I should add when I log in using the plusdls loggin on my router it doesn't seem to do anything. I tried to reset my password just incase it's wrong which I don't think it is but though I'd try it anyway, and then it says you are already connected to internet. The router goes blue but can't reach anything online. The router then says my username is setup@plusdsl.net. don't know if this helps or not
Legend
Fixes: 254
OK - your username is whatever you agreed with Plusnet at sign-up and should be entered, along with the also agreed password, and the 'save' button pressed,whilst the DSL cable is unplugged.
sjohnson
Given it another go and still not working. I'll have to keep my fingers crossed and wait for morning
Legend
Fixes: 254
As said, @sjohnson - it can take up to midnight of the activation date you are given, and the best advice is to leave the equipment alone until the following morning. IF you still have problems tomorrow, we can have another look.
