No broadband connection
Dpennycook
My broadband has been down since this afternoon and is unable to connect. The router shows an orange light and I have tried to reset the router but it still fails to connect, unsure if this is due to an outage in the area or me specifically.
Is there a site I can check for local outages?
8 REPLIES 8
Legend
Fixes: 253
Re: No broadband connection
Unfortunately there isn't one - that I know of - but if you could post a screenshot of your Hubs Help Desk page it may tell us something.
How have you tried to reset the Hub?
Dpennycook
After it failed to connect I tried the reset option but didn't seem to make a difference Stuck on the page that says you aren't connected to the internet and to check username and password
Legend
Fixes: 253
Apologies for the late reply, @Dpennycook . If you haven't done so yet, try resetting the Hub - hold a paper-clip or similar in the reset hole on the back of the Hub for 30 seconds or so until the light goes green, and then give it 10 minutes to reconnect.
Dpennycook
Reset the hub with a paperclip and waited ten minutes but it is back to the orange light with no connection
Legend
Fixes: 253
OK - looks like you need Plusnet Help Team assistance. No doubt they'll get to you tomorrow.
Dpennycook
Broadband has now came back on so it seems to have done the trick, thanks for the advice
Legend
Fixes: 253
Thumbs_Up
TheMightyAJ
Fixes: 126
Hi @Dpennycook,
I'm sorry to hear that you'd had issues with the connection yesterday, though I'm glad to see it's back up and running. Please let us know if there are any further drops and we'll be more than happy to take a look into this with you.
 Alex H
