No broadband connection since switch from sky
raysauce
Switched from sky broadband yesterday & still no internet connection. Household devices appear to have connected to hub & light is stable blue but no access to internet. Each time you try it goes to dsl hub login page with no option to login? Help
18 REPLIES 18
Legend
Fixes: 255
Re: No broadband connection since switch from sky
Welcome to the forums, @raysauce . Have you had notification from Plusnet that you are good to go? This sounds as though the automated systems have not finished configuring your connection, which can take up to midnight of your 'go-live' date.
raysauce
Hi John & thanks for the swift response. For clarity. Sky cut me off about 10am. email received from plusnet around 11am to confirm line had transferred. Email to confirm broadband was set up & good to go about 15:30. Followed every possible troubleshooting guide since & still no joy. There is no issue with any of my hardware as all worked fine prior to switch. Doesn’t connect through Lan network through Ethernet cable either. Pulling my hair out here John as now been another full day without internet.
Legend
Fixes: 255
Ray - I assume you have a PN Hub 0 as you are posting on the ADSL board? Unfortunately, I have no experience of that modem/router, so to help me help you, is there any way you can post a picture of the hub login page?
raysauce
Don’t think so John unless I’m missing something. For reference I am using plusnet hub 1. Forgive my ignorance if I’ve posted in wrong forum, just presumed adsl was appropriate place to ask for help as plusnet live chat off line & nobody answering phone either. So frustrating. Can answer hub login questions if you have the time to assist?
Legend
Fixes: 255
Okay, as I have no experience of the hub1 either, I'm going to be struggling a bit. What lights are on the router, and what colour/what are they doing?
Are you on an ADSL or FTTC connection, although it doesn't really matter at this point in time?
raysauce
Yeah lights have been solid blue for over 15 hours now which makes it all the more confusing. We have approximately 15 different devices in the house that all have successfully connected to the hub/router but none are able to connect to internet. Bizarrely google chrome works on a couple of the laptops but no site options it returns will connect? I’ve never experienced anything like this before & have switched many times over the years?
raysauce
Unlimited fibre if that helps.
Legend
Fixes: 255
Now I'm really confused. You say you have got Google to connect, but can get no further - I'm wondering if your devices have retained the Sky connection details? Just one suggestion for now - completely power down one device - preferably a desktop/laptop and then restart it and see if it can pick up the Plusnet connection credentials.
If that fails, I'm afraid you may have to wait until I can ask a more experienced member if they have any ideas, but unfortunately, all the people I would normally ask appear to be offline.
FYI - You should really have posted on the 'Fibre' board, but don't worry.
raysauce
No worries John. Duly noted & sincere thanks for sticking with me on this. Much obliged fella. Have a nice evening. If you get any ideas having slept on it don’t hesitate to shout up. Thanks again pal.
Legend
Fixes: 255
No problem - that's what we're here for, and don't worry, we'll get you sorted. I'm totally self-taught on this, and don't know everything, but there are more experienced members who will help when they spot this.
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
Fixes: 395
@raysauce
Two possibilities
1) the Hub one hasnt been associated correctly with your account and so the auto configuration isn't working. If you login to the router, does the broadband username show as setup@plusdsl.net ?
If so , then click the disconnect, go to settings>broadband and change the username to youraccountname@plusdsl.net and the password to your password, then click connect. If the led goes blue then you should be good to go, if not then 2) below probably applies
2) your account hasn't been fully activated yet, in which case we need a plusnet staffer to rectify
Legend
Fixes: 255
Thanks, @MisterW .
Fixes: 395
@jab1 no problem John, let's hope it's number 1.
I dont normally use the Hub one either, but I happen to have one connected to my network as a switch and so was able to log in and check the menus
