No broadband after switching to Plusnet
- No broadband after switching to Plusnet
08-10-2018 1:36 AM
Just switched from BT to Plusnet last month. Everything seemed to be working well after switchover but to cut a long story short it turns out that only the phone line was switched, and the broadband remained with BT. BT have now switched off the broadband and I was told my them it should revert to Plusnet and continue working. Turns out it doesn't and I now have no broadband.... who do I speak to to fix it? Plusnet tell me it's BTs problem, BT tell me it's Plusnet's problem and I seem to be paying both companies for broadband I don't have......
Re: No broadband after switching to Plusnet
08-10-2018 2:09 PM
08-10-2018 3:11 PM
08-10-2018 9:21 PM
24-10-2018 6:39 PM
I still have no broadband, and no one seems to be able to tell me what's happening?
25-10-2018 9:17 AM
I've just added an update to your account about some repair work taking place: https://www.plus.net/wizard/?p=view_question&id=183372308
27-10-2018 9:20 PM
It gets better! So after the third engineer visit he comes round the house and tells me there has been a technical problem during the switchover from BT to plusnet and that all the companies are out of sync and there is no issue with the wiring. His boss says Plusnet have actually cancelled the broadband so there is no way he can connect the line to it from the box. The only way he can get it working is to get plusnet to cancel everything and re-order the broadband from the start, at which point all companies should be in sync again and it should work.
So i call plusnet and they say there is no evidence of any of this from BT openreach and that they will not cancel my broadband and re-order it as i am in contract. If i insist I will have to pay cancellation fees as they think i am lying! [-Censored-]
So what do i do now? The engineer has been booked to come back on monday, I see if i can get written evidence from him so i can prove it?
28-10-2018 2:34 PM
Hi @DrPies,
Looking at the notes on the fault report on your account, we've been advised that our suppliers built the connection to the incorrect fibre cabinet.
Judging from the notes, the initial engineer couldn't update the routing for the line so they could then cease and re-provide the circuit on the correct routing (This does not require you to close your account and would be done by our suppliers)
The most recent engineer should have updated the routing but doesn't appear to have done that, and instead has asked you to contact us to cease your line and re-provide it, but until they've updated the routing.
I believe the engineer on Monday should be updating the routing as the previous engineer should have.
29-10-2018 4:25 PM
29-10-2018 8:55 PM
