No broadband Router Issues 09/01/21
holster1985
Hi. I've had no internet all morning. Tried to factory reset twice. My login and password are correct. Just wanted to know if there was an issue in Shrewsbury? Thank you
8 REPLIES 8
Legend
Fixes: 255
Re: No broadband Router Issues 09/01/21
What lights (if any) do you have on the router (which one), and what are they doing, @holster1985 ?
holster1985
Hi, thanks for the swift reply. It's just showing a static orange bar. None of the b's are lit up.
Tags (1)
Legend
Fixes: 255
OK. Have you checked the phone for noise, and are you on ADSL or Fibre?
holster1985
Phone line is fine. I'm on fibre. The b has now turned red but I'm using my correct password. Thanks
Legend
Fixes: 255
My only suggestion in that case, is to contact Plusnet. You posted on the ADSL board, where things are slightly easier to diagnose, but if you're on FTTC with an OK phone, but no broadband, it needs PN/BT intervention - sounds like a BT network problem, but I'm not a Fibre customer, and have little experience of that technology.
holster1985
Apologies, just spotted that! Panicking as working from home. Thank you for your advice. I'll give them a call.
RealAleMadrid
Aspiring Hero
Fixes: 59
@holster1985  Looking at this link there are a number of faults reported on the Shrewsbury area code, looks like an area fault so you just have to wait and hope it is fixed soon.
https://status.zen.co.uk/broadband/outages.aspx
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
