No Speed Change after Upgrading to Fibre Extra
- Re: No Speed Change after Upgrading to Fibre Extra
28-03-2020 10:21 AM - edited 28-03-2020 10:21 AM
I recently upgraded my Fibre broadband package to Unlimited Fibre Extra on 24/03/2020, and I received an email on 25/03/2020 to say the order has been completed. However I am still experiencing the same speeds of 40 mbps down and 10 mbps up. I have tried restarting my router (not a plusnet router) multiple times, but to no avail.
Hope you can help,
Regards
Chris
29-03-2020 8:27 AM
29-03-2020 12:13 PM
I don’t know if this is a definitive test but if you go to BTW Performance test site run the speed test and then choose the diagnostic test. If the upstream is showing 10Mbs you are probably still on standard fibre, if it’s 20Mbs you should be on Extra.
Link to BTW site: Click here
29-03-2020 2:50 PM
