No Internet, Secured
Emmagoo
Hi, we had plusnet fibre fitted 2 weeks ago. It's been working fine on our phones, tablets, tv etc. Today I have tried to connect my work laptop and it connects fine, but then says 'no internet, secured'.
Does anyone have any suggestions for fixing this?
1 REPLY
Fixes: 78
Re: No Internet, Secured
It might be that your work machine is set to connect to a VPN or might be trying to connect over a proxy that only allows connections to certain websites.
Have you checked your browser settings to make sure that's not the case
 Adam Walker
