No Internet - Can't Establish PPP Session - CHAP Authentication Issue - Password not changed.
FIXED- Subscribe to RSS Feed
- Re: No Internet - Can't Establish PPP Session - CH...
22-09-2017 1:56 PM - edited 22-09-2017 1:59 PM
Come home from work and the Internet is down. The router is unable to establish a PPP session due to CHAP authentication issue.
I've carried out the following steps:
1) Rebooted Router - not fixed
2) Swapped back to Plusnet Hub Zero router - still not working
3) R-entered username and password in hub zero -still not working
3) R-entered username and password in hub zero - no effect.
4) Rebooted Openreach Modem - Resynced fine - no effect. DSL Stats shows the modem in sync at same speed as before reboot.
6) Tried laptop connected to Openreach modem with PPP client, no connection - authentication error.
Anybody else got any ideas?
I've run through the broadband fault checker and its logged a ticket #158370247
Anybody else on here got ppp auth issues today?
I would be grateful if one of the staffers on here @Gandalf or someone else could have a look at this from Plusnet's end as my config hasn't changed and it was all working OK yesterday.
Fixed! Go to the fix.
22-09-2017 2:07 PM
Well, after over and hour of no internet, the router has finally established a PPP session. Wonder if I had a stuck PPP session at the Plusnet end or some other issue in the Plusnet network.
Looks like there may have been a power interruption earlier on today as the clock on the oven was flashing with the wrong time.
Re: No Internet - Can't Establish PPP Session - CHAP Authentication Issue - Password not changed.
22-09-2017 2:26 PM
22-09-2017 2:36 PM
Thanks @Gandalf, fingers crossed it was just a glitch in the BT network.
22-09-2017 2:50 PM
I could be wrong, but I suspect it's due to an incident we've been investigating at this side (ref:102291).
23-09-2017 9:53 AM
23-09-2017 2:05 PM
Thanks for running the test @Gandalf, everything has been working fine since.
02-10-2017 8:35 AM
02-10-2017 10:09 AM
It's not unknown for some routers to strip them out and cause authentication failures. E.g. & % @ " ' \ < >
