No Internet - Can't Establish PPP Session Authentication Issue .
Girlypink907
No internet connection this evening. Tried everything router lights orange. Try to log in but won't authenticate my ppp or something. Any ideas,
3 REPLIES 3
dgw1
Re: No Internet - Can't Establish PPP Session Authentication Issue .
I guess the obvious things are checking the phone line for a dial tone. Replace the filter if you have a spare one. If you are running the router off a extension lead/plug, try plugging it directly into the master socket. Other things you can do is plug just the one computer into the router using a ethernet cable and disabling the wifi on the router. You could also check your area to see if the service is down at the moment...Perhaps a call to PlusNet and ask them if they can check the line for you...
southerner
Sounds like a hung PPP connection. This should resolve itself over a few hours but if not I guess it would be best to call in.
MatthewWheeler
Fixes: 479
Apologies for the delayed response.
I can see this is sorted now and you're back online.
 Matthew Wheeler
