No Fibre?
techniz
No Fibre?
Fibre was supposed to be activated yesturday 27/10/2017 - however still nothing next day (today).  Hob One router keeps saying password or username not recognised.  The default account setup@plusdsl.net seems to connect and light goes blue, but no internet.
Have tried calling but 20 minute que at present - is anyone able to take a look?
regards
jon
techniz
Re: No Fibre?
All working, but at half estimated speed
Estimated 32-40mb
Actual - 16mb
Will give it a week and see what happens speedwise
etdsaunders
Fixes: 7
Re: No Fibre?
Maybe @Gandalf will pick this up, looks like profile may need a nudge. If not maybe some line tests
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
Fixes: 348
Re: No Fibre?
Hi Jon,
It doesn't look like your account is yet fibre.
I'll sort this out for you now. Smiley
Fixes: 348
Re: No Fibre?
Done that for you now.
Can you reboot your router and let us know how your speed looks?
techniz
Re: No Fibre?
Still the same 16mb down & 2mb up
Fixes: 348
Re: No Fibre?
Note to self: next time test the line first.
It looks like your router is in sync at a slow speed:
Sync Status In Sync
Downstream Speed 17.0 Mbps
Upstream Speed 2.0 Mbps
I'd run through the troubleshooting here and raise a fault to us here if your speeds don't change.
Sorry for any inconvenience caused.
techniz
Re: No Fibre?
I logged a support ticket as nothing has changed in the past few days
Fixes: 55
Re: No Fibre?
Hi techniz,
I've reported the fault with our supplier and added updates here for you: https://www.plus.net/wizard/?p=view_question&id=160965530
 Adam Walker
