No Fibre connection yet phone is ok. Had a line fault recognised recently...
- No Fibre connection yet phone is ok. Had a line f...
10-02-2016 10:54 AM
Information below.
ATU-R Information
Type: VDSL2
Hardware: Annex A
Firmware: 05-07-04-03-00-07
Power Mngt Mode: DSL_G997_PMS_NA
Line State: TRAINING
Running Mode:
Vendor ID: b5004946 544e0000
ATU-C Information
Vendor ID: 00000000 00000000 [unknown]
Line Statistics
Downstream Upstream
Actual Rate 0 Kbps 0 Kbps
Attainable Rate 0 Kbps 0 Kbps
Path Mode Fast Fast
Interleave Depth 0 0
Actual PSD 0. 0 dB 0. 0 dB
Near End Far End
Trellis ON ON
Bitswap OFF OFF
ReTx 0 0
SNR Margin 0 dB 0 dB
Attenuation 0 dB 0 dB
CRC 0 0
FECS 0 s 0 s
ES 0 s 0 s
SES 0 s 0 s
LOSS 0 s 0 s
UAS 0 s 0 s
HEC Errors 0 0
RS Corrections 0 0
LOS Failure 0 0
LOF Failure 0 0
LPR Failure 0 0
NCD Failure 0 0
LCD Failure 0 0
NFEC 0 0
RFEC 0 0
LYSMB 0 0
The connection was lost at exactly 12am last night for some reason.
Please advise on the resolution.
Kind regards.
Re: No Fibre connection yet phone is ok. Had a line fault recognised recently...
10-02-2016 3:39 PM
Please look into this.
Thanks.
11-02-2016 7:24 PM
Essentially my fibre has been re-ordered?!? after nearly two years of a working connection at the premises.
When is this being resolved? My connection has been cancelled and re-provisioned with no authorisation from myself, nor have there been any billing issues and prior line-issues were apparently resolved.
If this "switch-over" will improve my service, please go ahead; provided i am informed i have no issues with scheduled down-time in lieu of a better service.
Otherwise, revert back to what i was on before because it worked!
11-02-2016 7:35 PM
11-02-2016 7:54 PM
I have been on the internet some time before BT even started an ISP so please don't prevaricate, I assume plus net read these and its a one and only complaint from me which is easy enough to sort for them. If it doesn't happen I am gone.
PING irb.10.PTW-CR01.plus.net (84.93.249.1): 56 data bytes
--- irb.10.PTW-CR01.plus.net ping statistics ---
3 packets transmitted, 0 packets received, 100.00% packet loss
round-trip min/avg/max/stddev = 0.00/0.00/0.00/0.00 ms
12-02-2016 5:01 PM
Let me reiterate.
Until midnight ( ) of the 9th, i have had a working PlusNet fibre connection since June 2014.
I reported issues in the last two weeks and up to now was fully notified and updated of the stages of the fixes. Indeed once this line fault was fixed (so i've been told), my fibre had worked at a sync speed of 65000/20000 for several days.
Out of nowhere, a change has been made to my working connection that disabled my fibre completely.
Presumably an engineer was at the exchange at midnight and his actions caused this change, and presumably the work is logged.
Therefore, why is another engineer not being informed that the previous work has disabled my connection, and has not been sent to the same exchange to resolve this?
There does not need to be a due process or a waiting period, or a rebooking where 'undoing the mistake' is fitted in when convenient. There needs to be a phone-call that say's "hello, you left one of our paying customers offline when you did whatever work you were doing, go back and sort it!".
14-02-2016 7:03 PM
No fibre for 5 days now
15-02-2016 10:45 AM
We're back in the working week now and there's ample time for paid contractors to be assigned to rectify the mistake they have made: Please advise me on the schedule that has been given to the suppliers and their staff who will be responsible for reinstating my connection that is down to an admin error and not a technical fault.
Kind regards.
15-02-2016 12:15 PM
16-02-2016 9:11 AM
Unfortunately I've not been able to place the new order as the order that is causing the issue is still showing as open on the suppliers systems so I receive an error when trying to place a new one. I've sent a message to our supplier team to chase this up.
19-02-2016 9:10 AM
The suppliers are now impacting on the reputation of Plusnet themselves and if it wasn't for the hassle of migrating i would be looking for another provider today; as this goes on i will be more inclined to "deal with the hassle" and cut my losses.
I need a timescale update of the stages of resolution from Plusnet and the suppliers themselves today. Already at 9 days (soon to be inevitably 12) if i am reading the terms stated on the site correctly there is now a breach of the agreement. I understand it is not the fault of customer agents only going about their job, however now the next level of the resolution process must be held to task as this timescale is now unreasonable, no matter the process involved.
It seems as if the suppliers are simply not interested at this point, and while this is likely to be out of Plusnet's hands to a point, unfortunately this tardiness does not reflect well on them at all.
Basically, sort it. At the very least tell me when it is going to be sorted, and if you are waiting on a response from an outside party, get this from them today so i can plan accordingly.
I am due to be billed on the 25th. I state here that if i am not connected by then at the absolute latest i will be looking for another provider.
Regards.
