No DSL sync after fibre upgrade
- Re: No DSL sync after fibre upgrade
14-12-2016 4:02 PM
I was upgraded to fibre on Monday, but it's all gone a bit wrong!
The DSL light is just sat there flashing, taunting me. I've raised a fault, but what's the turn around for a FTTC fault like this?
Also, if the phone line is over a certain length, will the sync just fail, or will it keep dropping like an ADSL connection would?
Estimated speed is between 4 and 8Mb on fibre.
Ta!
15-12-2016 10:44 AM
Hello there,
Sorry to hear you are experiencing problems with your new fibre install. It looks like to progress the fault we'll need to arrange an engineer appointment. Looking at your account I can't see that we've ordered you a fibre modem/router.
Are you using your own equipment, and have you tried connecting the router into the test socket (Found by unscrewing the faceplate of the master phone socket).
Feel free to let me know and I'll be happy to work your ticket on your account to progress the fault.
15-12-2016 11:39 AM
Thanks for looking Anoush.
I didn't order a Plusnet router as I was ordering a TP-Link VR900 at the same time.
I've tried in the master socket without the faceplate, and with a different filter - no difference.
Many thanks.
15-12-2016 12:40 PM
I've updated your ticket, if you let me know once you reply I'll get the engineer booked in for you.
15-12-2016 2:16 PM
Many thanks Anoush.
I've updated the ticket
15-12-2016 3:02 PM
Engineer's all booked in for tomorrow between 1pm and 6pm.
I hope it goes well
19-12-2016 10:30 AM
What happens now? I've been without internet for a week.
19-12-2016 11:08 AM
I'm really sorry to hear this. That's probably the worst possible outcome
What we'd usually do now is to offer to downgrade your service back to ADSL. If you would like to go ahead I'd recommend speaking with our Customer Options Team on 0800 013 2632.
