Newish fibre install - Confused!
- Re: Newish fibre install - Confused!
18-11-2015 9:05 PM
Finally got fibre installed on the 2nd attempt and reasonably happy (hard to be when it's such a big step from the 0.4mb/s I was getting) but I do have a few issues with it that I cannot get my head around.
When I started looking at fibre this is what I got as being achievable
BT Broadband checker says
FTTC Range A (Clean) 80 80
FTTC Range B (Impacted) 80 76.7
From the BT wholesale website it says that the 'IP Profile for my line is - 70.08 Mbps'
From Plusnet
Current Line Speed 78 Mb
Most speedtests tend to come in most times at about the 63mb/s (download) range although tonight BT wholesale: Download speed achieved during the test was - 45.67 Mbps
For your connection, the acceptable range of speeds is 40 Mbps-70.08 Mbps.
Upload via the BTWholesale was even worse: Upload speed achieved during the test was - 2.6Mbps although usually most sites tend to be about 17/18mb, which to me is fine.
But why the difference in the download speeds? And why is the IP profile set to 70.08Mbps when the current line speed is shown as 78mb.
Am I getting the max for the connection (it's not as if the cabinet is that far away) or is something not quite right?
I might add that the engineer who installed it said he would phone me back with the speeds. Never did hear from him again. He also turned up with a 2nd hand OR modem!
Inspires confidence...not!
From Plusnet
Ever helpful. Sure, I’d love to help you out. Now which way did you come in?
Message 1 of 6
(1,231 Views)
5 REPLIES 5
18-11-2015 9:24 PM
Are you testing wired or wireless & if the latter, are you using the PN supplied router?
Message 2 of 6
(469 Views)
19-11-2015 5:52 AM
I'm currently using my TP-LINK Archer C9 AC1900 Wireless Dual Band Router but I've also used the Plusnet supplied one. I've tried testing - wireless and wired (with a slight difference in the Plusnet router). The TP Link is using 802.11ac. The router is 3 metres away from the desktop computer. Either way, results in the same maxed download speed. Most I've ever seen is 67mb and that was on the first day of connection. As mentioned, 63mb seems to be flavour of the month across most speedtest sites I've tried.
Message 3 of 6
(469 Views)
23-11-2015 2:58 PM
I'm sorry to hear that the speeds are lower than you expected, first thing I would suggest is going through making a PPPoE connection as per this link:
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
If the speeds are still poor on this type of connection then raise a fault here: http://faults.plus.net.
Thank you.
Thank you.
Message 4 of 6
(469 Views)
24-11-2015 6:08 PM
Strange things a foot.
BT IP profile is now 70.72. Plusnet Current line speed: 70.6 Mb
Speeds seem to be going up as well 65mb (wireless) seems to be average. When n one is using the internet, I'll disconnect the router and give the direct modem connection a go.
Be interesting to see what I get.
Thanks MelRocks
Thanks MelRocks
Message 5 of 6
(469 Views)
25-11-2015 8:10 PM
Quote from: MelRocks If the speeds are still poor on this type of connection then raise a fault here: http://faults.plus.net.
Thank you.
Carried out a couple of speedtests using just the OR modem via PPPoE. I've raised a fault. Seems both tests report around the same level 66 / 67mb's is max.
Thanks for your help
Message 6 of 6
(469 Views)
