Newbie install question.
- Newbie install question.
29-01-2015 1:11 PM
Hi having fiber installed on 2 weeks time.I believe Openreach install a modem that will plug into the new router that plusnet are sending.I would much prefer to use my own router which is a Netgear DGND3700 v2 which has a plug the back for fiber/cable.So my question is will i just have to change the setting on the netgear?
Message 1 of 3
(534 Views)
2 REPLIES 2
Re: Newbie install question.
29-01-2015 1:39 PM
Yes, you'll need to configure it for a PPPoE connection using your PlusNet username & password on the WAN port.
Quote So my question is will i just have to change the setting on the netgear?
Message 2 of 3
(290 Views)
29-01-2015 1:48 PM
Many thanks
Mike
Mike
Message 3 of 3
(290 Views)
