Newbie - broadband speed
FIXED- Subscribe to RSS Feed
- Newbie - broadband speed
05-03-2018 4:30 PM
I moved to PN and my fibre was activated on 20th Feb, when I do a speedtest I dont seem to be getting the speeds I should be?
I have attached Router and DSL checker info (I think this is the correct info).
Can anyone tell me if I am correct?
Thanks.
Fixed! Go to the fix.
Re: Newbie - broadband speed
05-03-2018 4:56 PM - edited 05-03-2018 4:59 PM
Welcome to the forum.
BT says that with a good connection you should sync down between 24.7 and 16.5Mbps and up between 1.2 and 0.8 Mbps. Your router is reporting that you are actually in sync at 17.966Mbps down and 1.137 up. So there's no problem there.
What speed are you getting reported by speed test and is it wired or wireless? It could be that you have a wireless problem.
05-03-2018 5:04 PM
Welcome to the forum @mrsmo
I agree with much of what @Baldrick1 says above but I wondered why you thought that you were running slow. What speed you are actually seeing with a wired connection to your router? Try http://www.speedtest.net/
05-03-2018 5:37 PM
Thank you both for answering.
I have unlimited Fibre, speed upto 38mb, when I do a speed test I am getting about 16.50?
I possibly dont have the full grasp of the figures etc
My laptop is one of those skinny ones with no ethernet socket, so its unwired.
It was more curiosity, I have no problems downloading etc but when I see 38mb I thought I might get that?
05-03-2018 5:50 PM
Thanks for those results. I'm afraid that you won't get much better speed than you have now.
05-03-2018 5:53 PM
Ok thats fine as long as I know, thanks for your help.
06-03-2018 11:06 AM
Hi there and welcome to the community forums.
As others have indicated it's unlikely you'll be able to achieve more speed due to the length of your line.
I've run tests down your line and everything is looking spot on within expectations.
Please let us know if you need any further assistance.
