New upload speeds
dabow
New upload speeds
I have been informed  by PN that my connection has now been updated to the new upload speed. This amounts to a "wonderful" 3.8 Mb/s  from what was 1.85.
I have a good regular download speed of 36/37 Mb/s so my connection is fairly decent. I feel the 3.8 speed seems to be well below what I would expect with  a decent connection. I would have thought  8 Mb/s might be expected.
Anybody know if this will improve ?
Browni
Aspiring Hero
Fixes: 47
Re: New upload speeds
What do the estimates on http://dslchecker.bt.com/ show?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
dabow
Thanks for the reply.
The BT info is shown below:
VDSL range A
Down  48.2 high    35 low
Up        8     high     5.5 low
VDSL range B
Down 37.5 high    21.5 low
Up         7.5 high    3.8 low
From the above  I seem to get the down speed on range B at the high end, but at the low end on the up.
Do I read from this I should get really about 7 on the up since I get almost 37 regularly on the down ?
Fixes: 4
Whats your connection speed in the helpdesk section of your router ?
dabow
Router info:
Data rate  4061/39993
Fixes: 4
Sorry I ment Maxdata rate, might as well post snr as well
dabow
Extra router info:
Max data r.      4157/43859
Noise margin    6.3/7.9
Line attn.          33.2/23.8
Signal attn.       21.2/21.2
Thanks for your attention.
Fixes: 4
Here's my line adviser, I can also tell you that my line is about 850 meters from the cab, with that said your line looks about right to me. thats just the way it roles sometimes I'm afraid Sad
My Connection speed etc
Max:	Upstream rate = 6266 Kbps, Downstream rate = 47644 Kbps
Bearer:	0, Upstream rate = 2000 Kbps, Downstream rate = 40000 Kbps
	                High 	Low 	High 	Low
VDSL Range A (Clean) 	42.4 	31 	7.7 	5.4 	27.4 	Available
VDSL Range B (Impacted) 32.4 	18 	7.2 	3.6 	14.7 	Available
When I get my line updated I expect to get around 5.5mbps just to give you an idea. I guess you could play about with cables and maybe gain a bit more speed but your not going to gain a lot more tbh with all things considered.
Might be worth checking for Star Wiring I had an issue with that when I first joined plusnet, when fixed I gained a little more speed, I also changed cables to cat5e as well. But, like I said... for very small gains.
dabow
Thanks again for the info. and attention. I'll look into that star wiring you mentioned to see if any advantage can be gained.
Cheers.
