New to Plusnet
stulish
New to Plusnet
Hi i am getting Fibre BB fitted next week and i was wondering if i could use my old router (ASUS RT-N56U - http://www.asus.com/uk/Networking/RTN56U/) for the WiFi and just use a LAN connection from the router supplied and turn its WiFi off?
Fixes: 58
Re: New to Plusnet
No need to use the supplied router at all. Just connect the WAN port of your RT-N56U to the Fibre modem. Configure the WAN connection on the RT-N56U for PPPoE with your PlusNet username & password.
Re: New to Plusnet
Im using my DSL N55 U in exactly that way (N55U connected directly to BT Modem via lan port)
As far as I can see, the DSL N55U is the same as you RT N56 U, but it has a (now redundant) ADSL2 modem built in.
stulish
Re: New to Plusnet
Thanks guys,
Once it is set up i will give it a try
Regards
Stu
Fixes: 165
Re: New to Plusnet
If you have any issues just post back here and I'm sure someone will be able to help. Hopefully it'll just all work smoothly for you.
 Chris Parr
 Plusnet Staff
