New to Plusnet
- Re: New to Plusnet
New to Plusnet
23-07-2015 10:11 PM
Hi,Just joined Plusnet today everything went very smoothly.
Openreach engineer could not have been more helpful,he even moved the master socket from the hallway to the upstairs room where i have my computer.
He did not use the fibre extension kit but ran a new line in from outside, lucky he did as he said the connections were in a poor condition.
These are the speeds i am getting from BT Speed Test
Download Speed (Mbps): 73.93
Upload Speed (Mbps): 15.81
So at the moment i am very happy with how the day as gone, hope things stay that way.
Regards Jack
Regards Jack
Message 1 of 8
(1,153 Views)
7 REPLIES 7
Re: New to Plusnet
24-07-2015 9:40 AM
Hi Jack,
Welcome to Plusnet and the community forums!
Those speeds are looking pretty good, I miss the days of having fibre at home!
Message 2 of 8
(683 Views)
Re: New to Plusnet
24-07-2015 9:54 AM
@Jacrav - that is very good that the BT engineer ran in a new cable rather than use the existing extension wiring. I think quite a lot of the installers will readily use extension wiring where they can, despite it not being very suitable for a fibre connection.
In my case, the installer wanted to use existing extension wiring (flat cable). When I pointed out that I had pre-installed a good quality CAT6 cable (for VDSL2 extension), he used that instead.
Message 3 of 8
(683 Views)
Re: New to Plusnet
24-07-2015 11:14 AM
What speed tester is that and do you know what modem you have? If you're getting 73.98Mb/s downstream you ought to be getting over 18Mb/s upstream. There are a couple of reasons why you might not though.
Quote from: Jacrav These are the speeds i am getting from BT Speed Test
Message 4 of 8
(683 Views)
Re: New to Plusnet
24-07-2015 12:25 PM
Thanks to everyone for the replies.
Andrue, I am using the BT Wholesale Broadband Performance Test.
I am using the Router supplied by Plusnet
These are the latest
Download Speed (Mbps): 73.91
Upload Speed (Mbps): 16.28
Regards Jack
Regards Jack
Message 5 of 8
(683 Views)
Re: New to Plusnet
24-07-2015 1:23 PM
It was the modem I was interested in but if you're using the BT tester those figures may be correct (or at least as expected). Try http://www.thinkbroadband.com/speedtest.html?utm_source=mainsite&utm_medium=navigation&utm_campaign=... instead and hopefully it'll report over 18Mb/s. For some reason the BT tester always understates the upstream for me. I've carried out my own tests and confirmed that the TBB tester is more accurate.
Quote from: Jacrav I am using the Router supplied by Plusnet
Message 6 of 8
(683 Views)
Re: New to Plusnet
24-07-2015 5:35 PM
Hi Andrue, Using the thinkbroadband tester i am getting.
Download 74.3 bursting to 76.3
upload 18.3 bursting to 21.8
Regards Jack
Regards Jack
Message 7 of 8
(683 Views)
Re: New to Plusnet
05-08-2015 9:39 PM
Sorry for the late reply. Yeah those are good figures
dick:quote
dick:quote
Message 8 of 8
(683 Views)
