New to Plusnet
- Re: New to Plusnet
New to Plusnet
02-01-2015 3:56 AM
Hi i am getting Fibre BB fitted next week and i was wondering if i could use my old router (ASUS RT-N56U - http://www.asus.com/uk/Networking/RTN56U/) for the WiFi and just use a LAN connection from the router supplied and turn its WiFi off?
Message 1 of 5
(803 Views)
4 REPLIES 4
Re: New to Plusnet
02-01-2015 8:07 AM
No need to use the supplied router at all. Just connect the WAN port of your RT-N56U to the Fibre modem. Configure the WAN connection on the RT-N56U for PPPoE with your PlusNet username & password.
Message 2 of 5
(408 Views)
Re: New to Plusnet
02-01-2015 8:44 AM
Im using my DSL N55 U in exactly that way (N55U connected directly to BT Modem via lan port)
As far as I can see, the DSL N55U is the same as you RT N56 U, but it has a (now redundant) ADSL2 modem built in.
Message 3 of 5
(408 Views)
Re: New to Plusnet
02-01-2015 9:53 AM
Thanks guys,
Once it is set up i will give it a try
Regards
Stu
Regards
Stu
Message 4 of 5
(408 Views)
Re: New to Plusnet
02-01-2015 12:34 PM
If you have any issues just post back here and I'm sure someone will be able to help. Hopefully it'll just all work smoothly for you.
Message 5 of 5
(408 Views)
